rustler kit
Kahn
rustler kit - 10.01.2007, 12:57 PM
hey there...this maybe a silly question but i couldnt find the answer so here goes
i want to get the fastlane elec rustler kit (chassis bulks towers and arms) an the thing is this....it says that you can choose normal length arms rather than extended..but does this mean that the rears are normal and the fronts are extended so you can use the same offset wheels or are the front and back both stock dimensions..cause if they are completely stock i would rather widen the whole thing...
ok thanks guys
Kahn
snellemin
2 KiloWatt RACER
snellemin's Avatar
10.01.2007, 01:22 PM
You can order the kit that has only the front extended and the rear regular length.(this is what I have). There is also the 1" extended chassis available.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
I believe two widening options - 1 wider front to run same offset wheels all round - 2 wider front and rear to maintain offset.
The later means you need different driveshafts though.
