Should I try this? HV setup Questions
Should I try this? HV setup Questions - 10.26.2007, 10:46 PM
I just received a kontronik Jazz 40-10-32
Wanted to try it out in my hyper7 on 7s lipo with an aveox 36/24/3 motor.
Motor is 1300 kv
Batteries are 4000mah maxamps, a 3s and a 4s pack
Controller is good to 10s lipo
Not sure if 40 amps will be enough on power handling by the esc. Motor is rated as 26/40amps on the box, and is similar in size to a feigao L can motor.
I am sure the batteries can keep up, they work fine in my 10th scale setups.
Any info or ideas a re welcome, i know some of you guys have run kontronic and aveox before so let me know what you think.
lutach
lutach's Avatar
10.27.2007, 12:34 AM
I ran 36V with my Kontronik 40A controller. It was geared to the moon and it ran good. I ran my BPP truck on grass and the old capacitor blew.
Name:	3SL 40-14-32.jpg
ID:	3410   Click image for larger version
Name:	36v packs.jpg
10.27.2007, 01:28 AM
Good to know, I will give it a try. Do you have a link to the programming instructions for the jazz 40?
sikeston34m
sikeston34m's Avatar
Smile 10.27.2007, 01:34 AM
Try gearing it low at first and monitor temps. If the esc is running fairly cool, then gear it up some.
Is that a Car esc with brakes and reverse?
They have a really good line of ESC's, expensive though.
lutach
lutach's Avatar
10.27.2007, 03:17 AM
Here is the programming instructions for the Jazz:
http://www.kontronik.com/Downloadmess/JAZZ.pdf
English starts on page 25.
Aragon
10.27.2007, 05:44 AM
Keep us posted. I plan to run 10S HV with a Kontronik Jazz too. I didn't know they made a 40-10-32. I'll be using the 55-10-32.
Do you know how many poles your motor is?
10.27.2007, 11:26 AM
Not sure how many pole the aveox motors have. I think they are similar to the Neu motors, as Steve used to work for Aveox.
lutach
lutach's Avatar
10.27.2007, 01:35 PM
The Aveox has 4 poles. Look at what Steve Neu said here:
http://www.rcgroups.com/forums/showt...20#post8434283
marc993turbo
10.27.2007, 03:51 PM
Good evening from Germany...
I think itīs offtopic in this thread - but please tell me: which conversion are you driving? Is this a savage?
I searched your posts but couldnīt find a description of your car...
Marc.
lutach
lutach's Avatar
10.27.2007, 05:27 PM
Marc.
Hello Marc,
It is a bomb-Proof Products truggy.
