squeaky truck. can i use wd40?
t-maxxracer32
t-maxxracer32's Avatar
squeaky truck. can i use wd40? - 01.19.2008, 05:39 PM
hey guys my shocks and everything on my truck are exstremely squeaky im guessing the dirt did that to it?
anyways.
can i use wd40 to stop the squeaking and clean it at the same time?
will the wd40 ruin the esc motor?
im not spraying them dirrect but if a little extra gets on them is it a big deal?
thanks!
bluonyx
01.19.2008, 10:14 PM
I use WD40 all the time. Hasn't hurt anything yet. I don't spray the motor or ESC though. I do it in this order: Air, Water, Air, WD40, a little more Air, and rag to finally dry .
rootar
rootar's Avatar
01.20.2008, 11:14 AM
after i wash mine with soad and water in the sink (i pull the electronics out) with a old paint brush i dry it off with the air compressor and then wipe down the plastic arms with WD-40, it really makes them look new and mud doesnt stick as bad if you do it agian with the wd40 at the track.
ssspconcepts
ssspconcepts's Avatar
01.20.2008, 01:25 PM
Just my point of view...WD40 is technically an oil based detergent. It is good for cleaning parts...but for optimum performance you should follow-up with a light coat of machine oil on bearings (the kind that comes in a plastic bottle w/needle . applicator). For CVDs, hinge pins, and pivot balls I use a graphite/teflon powder lubricant. For gears I use moly grease.
My way may not be perfect but it works for me.
t-maxxracer32
01.20.2008, 01:29 PM
well i dont clean my trucks too often... only when i am going to take pics or something because they will just get dirty the next day.
i really should clean out my bearings and such but eh.
im lazy.
thanks for your guys responses
