MGM 9032 BEC Question
marcus
marcus's Avatar
MGM 9032 BEC Question - 02.10.2008, 08:31 PM
Hi guys.
I'm looking at the MGM 9032 Car/Boat controller and I have a question about the BEC function.
I'm guessing that due to the overkill in capacity this ESC is offering, the BEC would function for a high number of LiPo cells ?
On this controller, what's the Max lipo count that I have while still using the BEC function (without having to resort to UBEC options)?
Thanks
Marcus
bdebde
That's All Folks!
bdebde's Avatar
02.10.2008, 09:21 PM
It has no BEC, external one required.
marcus
marcus's Avatar
02.10.2008, 09:44 PM
Bugger. I wasn't expecting that !
Isn't that rather lame?
02.10.2008, 10:14 PM
Better to use an external bec, the internal one usually cause more problems than they cure. Anyway, a ccbec is fully adjustable so it is better than most of the internal becs.
marcus
marcus's Avatar
02.10.2008, 10:28 PM
Yea, guess I'll have to.
Geez, trouble is I live in Ontario and NOBODY sells ANYTHING here like that. We have to buy in from the States and it just takes a.g.e.s........ God, what a pain [boo-hoo]
marcus
marcus's Avatar
02.10.2008, 10:37 PM
I just found, downloaded and read through the manual and it says it has a BEC for use up to 4S.
I'm confused, was your comment a joke or sarcasm?
bdebde
That's All Folks!
bdebde's Avatar
02.10.2008, 10:51 PM
I have a 16024 (no BEC) and I have the manual right here in front of me; the 16024, 9032 and 12032 have no BEC.
marcus
marcus's Avatar
02.10.2008, 10:59 PM
Yea, please accept my apologies, you are totally right. I just found a different manual and indeed you are correct.
Sorry
Wow though, that sucks :-(
othello
HV basher
Have a look at the spec data of the MGM 9032 on MGMs website. Opto ... so no integrated BEC. You have to use an external BEC. If i'm not mistaken Finnster here uses an MGM9032.
Finnster
KillaHurtz
Finnster's Avatar
02.12.2008, 04:32 PM
Correct. i have one. Any controller that says "opto" means there is no BEC. If you want to use the full capabilities of the 9032, you need a BEC capable of ~40V. The UBEC Mike sells is one of the best of a small field of BECs capable of this.
azjc
07.20.2008, 07:25 PM
with an OPTO ESC is there a need to pull the red wire from the cable that goes from the ESC to the Rx when using an external BEC
