Align 600L with a Quark 65 Roadster
Align 600L with a Quark 65 Roadster - 03.14.2008, 10:33 AM
Alrighty then!
I have a fresh (to me!) hyper8 buggy that I plan on testing my align 600l motor in. Now I have a few maxamps 2100 based packs, enough to do 6s 4200 mah. So I plan to mount the motor where the gas tank would go, and make a pair of battery trays in the rear on either side of the rear chassis brace.
Methinks I can use one of my trusty quark 65 roadster escs to motivate this beasty. Here are the specs from align on the motor, 1620kv, and a 65 amp max. Now I know that the max amp rating is not based on land vehicle usage, just the trex600 heli.
http://www.align.com.tw/shop/product...oducts_id=1383
And the quark 65 is supposedly good for 65amp constant, 90 amp surge and 150 amp spike, so I figure it may be able to keep up?!
http://www.rc-monster.com/proddetail...oadster&cat=21
65amps at 6s would be almost 2hp, which were the highest recorded spikes in my 7xl, 4s powered buggy. I am guessing that adding an extra cap would be a good idea. Maybe I will add a heatsink to the case too.
Let me know what you guys think...
03.16.2008, 03:29 AM
Looks like I will be running blind with this one! I will post pics and info when I finish it.
03.16.2008, 10:44 AM
sounds like a neat project! the little 65 may get a little hot on 6s. what's your plan for gearing?
03.16.2008, 11:23 AM
Gearing will be 13/46 to start, and it has the std 43/13 diffs. I will run jumbo kongs. Just kidding, std buggy height tires.
