03.26.2008, 07:51 PM
I believe you basically need the LST2 alloy diff case and diff, then perform the required mods to a bit of plastic plumbing, and drill out a maxx diff collar.
I love my Ultralite/HB diff, but it is very expensive by comparison.
its me
There is no help for me... I'm addicted to R/C
its me's Avatar
03.27.2008, 02:10 AM
100% correct!
and yes ive been looking at the UE arms though im not sure if I want to use them??!?!?!
rccna.com
mriccucci
mriccucci's Avatar
03.27.2008, 08:23 AM
Ok so im really thinking about doing this conversion as the diffs are much cheaper then the hot bodies ones. My only concern is the outdrives for the transmission. Have any of you done a center diff in a stock chassis? And is not is it even possible?
its me
its me's Avatar
03.28.2008, 02:11 AM
Always some nice UE stuff on fleebay, especially A-arm kits complete with knuckles- depends if you want to spend that much money though?...
The bling can wait :) I wana get this sucker running
rccna.com
03.28.2008, 09:54 AM
mriccucci- A center diff on the stock 3906 or 3905 chassis would be entirely possible (anything is possible with the right tools & some imagination). I would envisage something like a center diff unit taken from a 1/8 buggy/truggy, mounted to a metal/CF plate, and then bolt that to the chassis rails/braces, so that the whole unit pokes up through the hole (which would need enlarging) in the middle of the chassis- then just run the center driveshafts to the front and rear diffs. The motor would need to be bolted to a seperate mount, above the chassis and be adjustable up * down for gear mesh. Not the simplest idea, but do-able with a little effort.
Yep, bling can wait, so long as the mutant truck actually runs, thats the important thing
mriccucci
mriccucci's Avatar
03.29.2008, 09:21 PM
Does anyone have a list of the major manfactures that run a mod1 gear in the center diff? Im looking to either fabricate a chasis around a center diff, or use the FLM Chassis and add a center diff plate. Any suggestions?
03.29.2008, 10:11 PM
Your best bet is a kyosho 44t plactic spur, and a diff cup from an ofna hyper, Hot bodies, or kyosho. They all fit the same way, and can use the same spur, internals etc.
its me
its me's Avatar
03.30.2008, 03:56 AM
Linc hit the nail on the head, MOST if not all 1/8th diffs are very similar if not interchangeable...The ones that I know off hand that are not are Sportwerks/Losi are a bit more narrow then others.
rccna.com
mriccucci
mriccucci's Avatar
04.01.2008, 05:02 PM
hey its me, im after a few of the compnets that you have used in your build. The first is the cross beams that you have? It looks to me like they came off a gmaxx chassis. The other is the main chassis plate. Im assuming that its home made. If so what did you use to cut it? And what thickness is the metal?
04.01.2008, 06:25 PM
Cross beams? You mean the chassis braces/rails- they are upside down FLM extended chassis braces.
04.01.2008, 10:20 PM
rc-monster center diff/motor mount for flm e-maxx chassis, sorry for the crappy pics
ID:	4356   Click image for larger version
ID:	4357   Click image for larger version
mriccucci
mriccucci's Avatar
04.02.2008, 08:38 AM
Any idea if i can buy just thoose from FLM?
04.02.2008, 05:34 PM
I dont believe so- you would have to email FLM and ask pretty-please to buy just them on their own, separate from the chassis.
Paralyzed- did you get them from Mike?
04.03.2008, 01:28 AM
suicide- yes, custom r/c monster! ssspconcepts and I are the only ones with one so far, he has much better pics in the customer feedback and testimonial section on the first page under the heading: RC Monster direct drive unit for FLM E-Maxx
its me
its me's Avatar
04.03.2008, 01:30 AM
WOW thats friken sweet!
Neil is right on everything :)
The chassis was cut with a jigsaw/file and a DA.
rccna.com
