What kind of balancing plug do I need for a Nue 5000mah 2s?
pullstarter
Pullstarter
What kind of balancing plug do I need for a Nue 5000mah 2s? - 04.01.2008, 02:43 AM
Hi Guys,
Think i've decided on the Nue 5000mah 2s pack to run in my touring car, what kind of balancing plug do these come with? Need to get a balancer at the same time so need to know which plugs or converter is required. Any help greatly appreciated, thanks guys.
Countryhick
04.01.2008, 04:18 AM
They have a Kokam balance plug which is an "EH" type connector. I got mine from HERE.
Hope that helps.
Cheers Andrew
pullstarter
Pullstarter
04.01.2008, 05:37 AM
So this fella would do the job?
http://www.rc-monster.com/proddetail.php?prod=CCB7TPQF
Thanks for the help cobber
Countryhick
04.01.2008, 06:03 AM
Not sure, maybe someone else can chime in with an answer. What charger/balancer are you using?
pullstarter
Pullstarter
04.01.2008, 06:09 AM
Will be charging with an ICE and balancing with an Apache SM505.
andy85
04.02.2008, 08:54 AM
NO it wont because Neu balancer tabs have clips on the two shorter sides....this converter looks like its got some kinda slot on one of the longer side.
pullstarter
Pullstarter
04.02.2008, 04:09 PM
Thanks for the help guys, much appreciated :)
