04.01.2008, 05:55 PM
Hmm, they really do look like a feigao inside, but the Neu looks very much like the Hvmaxx motors inside. For the money too, the Neu wins hands down.
I just wish more people used the pletts- precious little experimenting done due to the high prices....
Well Neil, I have a maxximium in my crt.5 on 3s and have been very happy with it. I will be trying it out in the new emaxx on 4s, as I now have a novak hv6.5 with the 5mm shaft for the crt.5.
I have a pair of trakpower lipos and a quark 125b to run the plett. I will gear for about 40mph.
sikeston34m
sikeston34m's Avatar
04.01.2008, 05:58 PM
Great Information Othello! Thank you for the post and the comparing pictures.
I've always heard Neu Motors as being the "rage". Now I understand more of why. It's a much better design.
That's a multipole field if I'm seeing this correctly. Is that a 12 pole field? How many poles are there?
Also, How many poles does the Neu armature have?
I might come to appreciate the quality of Neu now that I understand better. Hmmmmmmmm..........
04.01.2008, 06:00 PM
Cool- just dont go blowing it up on my account!
From the limited info I have read, it sounds like the Pletts prefer a larger load on them compared to other motors (higher pole count), but that kinda makes me nervous about how many amps it will draw through the esc it is connected to and such... so sexy though, I love those motors.
04.01.2008, 06:03 PM
Don't worry, I have no idea what I am doing so it will be ok!
Here is the suggested setup in the calc. IIRC the motor is 3100kv, correct me if I am wrong!
Differential Ratio: 2.8461538461538462
Transmission Ratio: 1.8333333333333334
Other Ratio: 1
Spur Tooth Count: 65
Pinion Tooth Count: 18
Total Voltage: 14.8
Motor KV: 3100
Tire Diameter (inches): 5.75
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 3.61 : 1
Total Ratio: 18.84259 : 1
Tire Circumference (inches): 18.06 inches (458.83 mm)
Total Motor Speed: 45880 RPM
Vehicle Speed: 41.65 mph (66.91 km/h)
Effective Speed Rate: 2.81 mph/V (4.52 kmh/V)
Estimated Adjusted Speed: 39 mph (63 km/h) - 5% loss
Effective KV Value: 3100
04.01.2008, 06:10 PM
http://www.plettenberg-motoren.com/U...tschrauben.htm
They dont make it easy to find the Kv data, but I tracked it down....
rhylsadar
rhylsadar's Avatar
04.01.2008, 06:24 PM
hi
the maxximum on 4s in the maxx will be nice. under real load i 'calculate' more with around 2700 rpmv.
btw here a pic of the inside of a plettenberg. looks kinda 'similar' to the neu.
bye
rhylsadar
______________________
Exercitatio artem paravit
rhylsadar at youtube
othello
HV basher
04.01.2008, 06:32 PM
@sikeston34m
correct: 12 pole field and 4 pole rotor
The only thing i don't like about those Plettenberg Maxximum/Bigmaxximum motors is their high KV. Those motors need good batteries and suck a lot of Amps (due to their high kv rating). But i red they can be wound differently at Plettenberg to get lower kvs. Other than that, they are one of the only motors truely built for offroad use. I almost bought one, but due to their integrated fan they were too long for my buggy project. Neu motors do have a good selection of windings to fit the motor to the choosen voltage.
04.01.2008, 06:38 PM
Yep, that is the only thing that puts me off really, and I dont fancy messing around trying to get a custom wound item- could cost alot of money and time, especially since Im over the pond. I wonder if anyone makes a motor heatsink of that design for Neu diameter motors...
04.01.2008, 06:48 PM
Hmm, wonder what the inside of an aveox motor looks like? I have a few, any ideas how to remove the endbells? I am guessing the front is screwed on, and the rear pressed on due to wires coming out the end?
04.01.2008, 06:52 PM
Originally Posted by rhylsadar View Post
hi
bye
rhylsadar
Thanks, I figured the spec was unloaded. It required me to step up 2 teeth on the pinion from what i figured in the crt.5 to get the desired speed. It works well on 3s, and never even gets warm. So I figured more load would not bother it. Plus I want the c50 hacker 14l out of the max and in the hyper8 buggy for testing on 6s lipo.
jhautz
jhautz's Avatar
04.02.2008, 01:14 AM
I toasted a Kontronics FUN1800. The thing got hot faster than the feigaos. It got over 300 degrees F on its last run. Oops....
Amazingly it still runs, but the burning smell never went away.
Took it apart and it still looked OK, just smells funny. Its been sitting in the motor box for quite a while now. If anyone needs a pretty paperweight or good hard drive eraser I'll let it go cheap.
to make it...
or break it...
Silent...But Deadly
rhylsadar
rhylsadar's Avatar
04.02.2008, 03:28 AM
i don't know how many A they really draw. your are right however on the very limited windings. but remember when those motors showed up. i can not date it exactly but when i made my first brushless savage in 2003 they were already there and quite common. so i guess they appeared around 2001 or 2002 or earlier? and what were the applications those times? mostly (3906) e maxxs running with 12 or 14 cells. a maxximum or bigmaxximum is perfect for such a setup of voltage and weight. by now things have developed and now converting truggies etc is common and the people have seen that high voltage setups are more efficient etc. especially due to the increasing use of lipos that made it more easily to go HV without too much weight. and so lower kv motors were needed and used. so plettenberg maybe should react to this with a lower kv bigbigmaxxium with around 1500rpmv.
when i started i got even recommendations of a C40 10L hacker for a savage.... and there were not few that used lehner basics in etc. of course there were also others like promod that already were with the big lehners and many cells. however it was not common to use HV setups with low kv motors at back then and i guess this is part of the reason why there are not more windings available.
bye
rhylsadar
Plettenburg Motors
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Plettenburg Motors - 04.02.2008, 04:16 AM
I have a Plettenburg "Big Maximum" motor on the way now, so once we get settled into our new home in Korea (July) I will post up some photos, vids, and stats from my experiences. From what I have seen and heard they are probably at the top of the heap in quality and performance. We shall see.
