brushlessboy16
brushlessboy16's Avatar
04.01.2008, 10:39 PM
Update Guys: I just had a freind order 50 330uF 25v capacitors, i plan to run them with the Mamba Max to lower the temps a little bit.
How many should i run? the more the merrier?
aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.01.2008, 11:20 PM
Put them all on there...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
brushlessboy16
04.02.2008, 06:26 AM
how many though?
Takedown
WARNING: May become violent.
Takedown's Avatar
04.03.2008, 10:07 PM
I would run 6-8 on a braket kinda like sike has on his outrunner e-revo.
RIP- Tammy (9/14/08)
brushlessboy16
04.04.2008, 09:02 AM
Hey Guys, Has anyone used the TeknoRc Battery tray?
http://www.teknorc.com/product_info....roducts_id=940.
It has the same exact dimensions as the Pack I'm getting and is cheap too, i might have to drill a couple holes in the chassis but it would look a heck of a lot better then what i was thinking :D
brushlessboy16
04.04.2008, 09:16 AM
According to all my measurements and calculations, the raze should weigh in somewhere around 9.5slbs, 10 lbs max.. And at full throttle, it will be making 3.7hp or 2590watts!!!!
that makes the power to weight ratio about .375 to 1!!!
Minding that the Buggati V16 Veyron has .230hp per pound... yay :D
GO OUTRUNNERS!
brushlessboy16
04.08.2008, 09:03 AM
Hey guys just a little update, my Order from United hobbies is still backorderd!!!! AHHH NOO
I have been wondering how you guys think i should mount the motor, right now my idea is to Machine a big hunk of .3'' thick delrin into a mount that would use the same holes as the center diff did.. Do you think it will be strong enuff?
brushlessboy16
04.10.2008, 07:01 PM
Does anyone know if a Motor mount made of 1/2inch Thick Delrin will be enuff for the motor?
Name:	Outrunner mount.jpg
brushlessboy16
04.21.2008, 09:22 AM
Hey Guys just a little update, my motor and Battery just came into stock and should be here shortly,It looks like the machined mount idea is a failure... might use some steel angle to make a mount, then either some round stock or flat plate for bracing... its really simple but should get the job done
04.21.2008, 09:45 AM
Why not use one of these
http://offshoreelectrics.com/proddet...od=ose-drmount
brushlessboy16
04.21.2008, 09:51 AM
Ehh a coupla reasons, i would like to make it myself for one, im not one to build things out of a box.... then b/c its not made for an outrunner motor, and because i need something that will keep the mount from flexing.
04.21.2008, 09:59 AM
Does the motor have screw holes at both ends? You could fab two of them together to make like a diff mount...
brushlessboy16
04.21.2008, 10:00 AM
no, only at one end, the other side of the endbell spins with the shaft.
rcmonkey
Team Thermal Racing
rcmonkey's Avatar
04.21.2008, 10:10 AM
What pinions are you planning on using with the 8mm shaft?
My Rides:
Tamiya Dark Impact - Team Losi Micro B - Cen Mini Madness - Soon to be BL Xray XB8 TQ
brushlessboy16
04.21.2008, 10:14 AM
It is an outrunner motor running direct drive, im running diff cups on the motor shaft and running dogbones directly to the front and rear diff
