Lipo setup advice please
Trick440
Lipo setup advice please - 04.07.2008, 03:18 AM
I have a Revo with the Neu 1512 2.5d/f, Quark 125b controller.
I'm looking to run 4 cells. First question, a 4s2p, is that considered 4 cells or 8?
I'm thinking about getting the NeuEnergy 25c 5000mah 4s pack. Or possibly a True Rc pack.
I need a charger, I want something that is AC powered. The HYPERION EOS0610I looks good but I think its only DC? Some chargers, charge faster than others? Also I need different connectors for hooking up different batteries to the charger? (eg. if I bought 1 NeuEnergy & 1 True Rc)
Sorry for the scattered questions. I could use your recommendations and/or suggestions. I need whole lipo battery setup, from battery, to charger, to balancer. I want the best bang for the buck.
I need to stay 4s or under, if I go more I need a seprate battery for my servos with the Quark? I think thats what i was told.
thanks and I appreciate the suggestions. Its all confusing to me.
glassdoctor
TEAM FUSION
glassdoctor's Avatar
04.07.2008, 03:33 AM
4s2p is a "4 cell" 14.8v pack.... but does have 8 cells inside. The 2p just means it uses pairs of cells in parallel to make up the total mah capacity of the pack. For example a 4s2p 5000 pack would be made using a total of 8 2500 cells. The 2500 cells would be put together in pairs to make 5000 "cells" (or batteries, technically).
You really should be using a separate source to power the rx and servo on 4s/14.8v.... use either a UBEC or RX battery. It will keep the Quark cooler and possibly prevent a complete meltdown.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
04.07.2008, 03:49 AM
Well, the true rc packs are great deals, lots of value for money there. And most seem to find that they are underrated, which is great for a product like that.
The neuenergy packs are nice. I have a 5000 3s pack and have been very happy with it.
As far as chargers go, a MRC 989 is an excellent all around charger. It comes with a power supply, and is easy to use. Do not forget to buy a good balancer. A hyperion lba 10 or flightpower v balance are both great investments, as they can handle up to 6s lipo. The mrc can do 8s lipo, and all nimh,nicd, and lead acid. I have one and really like it.
You will need to buy adapters to balance packs with differnt balance connectors (taps). Hyperion makes adapter boards that fit the lba 10 to mate with all of the different style taps.
Trick440
04.07.2008, 01:25 PM
Well I decided i got the Hyperion 0610i, a TrueRC 8000mAh 14.8V 4S2P pack (it didnt say if that T. Rc was a 10c or 15c, I was assuming it was 15c. Anyone know?) and a NeuEnergy 30/60C 5000 4S1P. That hurt the pocket book, but I should be tearing up the dirt.
83gt
04.07.2008, 02:04 PM
the truerc pack is 10c, and it does say in the product description.
J.
Trick440
04.07.2008, 02:18 PM
ahh ok. I didn't see that at first. Hope 10c will cut it.
83gt
04.07.2008, 02:28 PM
It should do just fine. The TrueRC packs seems to be underrated considerably. I found that I seem to get much better performance from them than my 100A rated maxamps packs. ;). Although I seem to be having an issue with one cell in my 4s2p. I hope it's just a one-off.
J.
