Thread Tools Rating: Thread Rating: 3 votes, 3.67 average. Display Modes
david lamontagn
04.07.2008, 11:41 PM
Looks good. I got my brake spacer from Mike on Thursday. I installed it over the weekend, but havent had a chance to post the pictures up. I'll do it tonight. It works just as planned.
Which brake spacer????? Can't find it on Mike store..
Brake spacer or Neu front bell cover????
jhautz
jhautz's Avatar
04.07.2008, 11:55 PM
David,
They arent in the store yet. I asked mike to make up a special one for me and he put his touches on it and I think he is going to add it to the store soon.
Here are a couple pictures of it and pictures of it installed on my buggy. Works perfect for me.
I installed it on a Neu at first, then I changed my mind and used a Lehner so thats why different motors in the pictures.
If you send Mike a note I'm sure he made a few extras.
to make it...
or break it...
Silent...But Deadly
jnev
jnev's Avatar
04.08.2008, 12:25 AM
Thats a cool little part to allow mechanical brakes. I'm just afraid that the shaft wouldn't stick out far enough for the pinion gear...
jhautz
jhautz's Avatar
04.08.2008, 12:28 AM
With the Neu motors there is no problem at all, they have unusually long shafts. The Lehners and Feigaos are starting to get to the end of the shaft, but its no problem. The shaft on my 1940 doesn't quite stick out the other side of the pinion gear, but it in there plenty that there should be no problem.
to make it...
or break it...
Silent...But Deadly
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.08.2008, 12:35 AM
Could you possibly flip the CD around? Or would that make the spur too close?
04.08.2008, 12:39 AM
I think he us using the tekno clutch thingy on this xray. It would fit fine the other way around, using a std pinion.
What's_nitro?
04.08.2008, 12:45 AM
Ahh, I didn't know he had the Tekno clutch thingy.
jhautz
jhautz's Avatar
04.08.2008, 12:53 AM
I have the CD flipped around cuz I was running the Tekno CLutch in that buggy. I actually just got done flipping it back around to get rid of the clutch and reinstalling the mechanincal brake servos and linkage. Heres a picture on it finished and the dif flipped back around the right way.
to make it...
or break it...
Silent...But Deadly
Shark413
Shark413's Avatar
04.08.2008, 01:37 AM
jhautz, that is a sweet setup. Looks like the spacer will work out ok. I am glad this post generated interest and lead to another cool RC-Monster brushless option for those that want to run mech brakes.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
opps!
entjoles
opps! - 04.09.2008, 08:30 PM
well i broke my servo case today, dont know if its from the minor flex in the way it was mounted or if it was from the fixed object i hit, but i will using a plate on the bottem of servo for a flat surface secured thru the bottem of the chassis and screwed into axial stand-offs and then mounting the servo to them on the top side, should be more secure and rigid
http://www.axialracing.com/details.php?Id=3416
heres some pics
any thoughts....
auto2
04.10.2008, 06:53 AM
i added rear brake only and am using mixing with electric brake . tested it last night and it works great.
with the long brake arm I have tons of leverage.
so far I tried 30 percent in the MM seems good.
when I enter a turn and tap the brake the rear comes around . turn off the rear brake and doing the same thing it pushes to the outside of the turn.
the cool thing is I can turn on and off the third channel while Im racing depending on track .
V2.0
entjoles
V2.0 - 04.12.2008, 09:42 PM
here is what i came up with to make it more rigid, hope it works, i have one more idea if this fails
i also need to de-ano the stand offs (7x30mm)
i changed to a plastic spur and will try 5s on my MM/9XL geared 14/46
jhautz
entjoles
jhautz - 05.08.2008, 07:16 PM
have you used this spacer with a finned can?? will it fit... i dont think there would be any trouble with it but would like to be 100% on it before i order my neu...
thanks
jhautz
jhautz's Avatar
05.09.2008, 03:02 AM
No, I havent. But I dont see why it woudnt work. If it will work without mechanical brakes, it should work with this spacer and mechanical brakes. The only reason it wouldnt is if the fins hit something on the chassis or the chassis brace or something, but then it would hit without the spcaer too. Id say your safe.
to make it...
or break it...
Silent...But Deadly
Shark413
Shark413's Avatar
05.22.2008, 02:02 AM
I was out for some practice when I noticed I suddenly had no brakes. Checked the buggy and found the horn had sheared off the servo. Hitec Karbonite gear broke in half.
