Losi LST BL
lucias
lucias's Avatar
Losi LST BL - 04.09.2008, 11:18 AM
You all being the masters of brushless and me bieng the noob... I was wondering what brushless setup you guys would recommend for an LST. I was contemplating the Fine Design one but it seem expensive for what you get.. You could almost do a Neu Brushless crazy fast setup for that much.. What motor/ESC would you recommend for an LST? I would plan on running lipos.. I really want a big powerful battery so I can geta decent run/bash time.. 4s for sure maybe 6s.. Would a Maxamps 10000mAh 5s 18.5V be out of the question? I want to build a monster...
04.09.2008, 11:37 AM
A feigao 12xl on 6s lipo would be a nice combo. I am sure that you will leave the mech brakes, so you can use an air esc, or possibly the MMM when it comes out. I am not sure of how to lock the tranny in the lst so that you can use motor brakes, but someone else here will chime in with the info.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
04.09.2008, 12:15 PM
Sounds good!!.. I wouldn't use motor brakes.. just more heat for the ESC... the mechanicla brakes are awesome, and they're not in ur way...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
lucias
lucias's Avatar
04.09.2008, 12:34 PM
What esc would be good like a Hydra 120 or would I need something like the Quark monster? Or would a phoenix 120 with a pix stix work just as good? Would a NEU motor be overkill?
Mozzy
Mozzy's Avatar
04.09.2008, 01:41 PM
The Quark Monster has been overshadowed by the now popular & better Quark SSB over here.
Takes up to 6S, no external BEC required as it has an inbuilt adjustable, the heatsink is mounted directly on the FETS, comes in a bundle box with a handheld controller, fan & wiring all for a measly $399Aud from Ark Innovations.
I'll be using this in my carbon LST2 with a Feigao 6XL, stock gearing & just to trial 3800Mah 4S 20C pack. This may be a perfect package (apart from the battery) for motor/gearing/ESC. My truck will weigh no more than 5.2kg ready to blast. It was previously 5.49kg rtr as a nitro.
Custom clutch adapter & motor mount. Adapter's done, but, still working on the mount. Going to mod a Tekno Revo battery tray to suit (my mate wanted blue straps, so, he gave me his black ones.).
I believe that any ESC without some type of cooling mechanism is a burnout waiting to happen.
lucias
lucias's Avatar
04.09.2008, 03:07 PM
Have any picutres? Where did you get your motor mount?
Mozzy
Mozzy's Avatar
04.09.2008, 10:39 PM
My mount is going to be a custom job like the clutch adapter, so, you can't buy it. When it's done, if it's any good I may get a bunch made up to sell including the clutch adapter as a kit.
To give you an idea of the clutch adapter, think of the Revo Tekno conversion, I took the adapter they made & changed it to suit my needs.
Mind you, mine is slightly different & will also work for other cars. It works beautifully too.
I'll wait till I get the mount completed & then I'll take a few pics of all the parts I'll use & post it as it goes together.
My mate's using a 7XL with RC Monster heatsink, MM with fan, Maxxamps 14.8v 6000mAh 4S with the Tekno kit, standard gearing & he went back to the locked centre diff to save tires & get the power down more easily.
He gets 25min run times & with the locked centre it pops a wheelie which you can hold for ages, when it kicks 2nd & 1/4 throttle. Off the mark on 80% punch control when nailed it jumps off the ground about 30cm & lands on it's lid! I loved driving it. Can't wait for mine to be completed, I will toast him!!
Just to enlighten you guy's, I'm changing to brushless due to health problems from breathing nitro fumes & I guess I just want some real power for a change. I'm considering the conversions for my Kyosho Kanai III buggy & my Hong Nor X1CRT. Although, the CRT is about to be superseeded by the X2 & I may just buy that as a pro kit & build it up as a brushless from scratch. Eh we'll have to see as I really don't have $600 spare for ESC's.
