solder motor directly to ESC?
Robl45
solder motor directly to ESC? - 04.19.2008, 01:24 PM
As the subject says. I got a used feigao motor from ebay and it has bullet connectors on it, but the local store doesn't have the big connectors that are on this thing, Can I just solder the esc wires into the bullet connectors? I can't remove the bullet connectors from the motor as they are attached right at the motor, there would be no wire left.
rabosi
04.19.2008, 03:05 PM
That would be ok.
04.19.2008, 03:41 PM
Yes DO NOT CUT THEM OFF... Just desolder them...
Robl45
04.19.2008, 09:45 PM
I could desolder them, but I will probably just solder right into the female bullets that are on the motor.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.20.2008, 01:33 AM
If you do that, you'll have to de-solder the connectors anyways should you decide to use them later.
azjc
04.20.2008, 03:00 AM
You could but the correct size of connectors on line.......that would be my suggestion
