VintageMA
VintageMA's Avatar
06.16.2008, 09:51 PM
Originally Posted by Jeremy1976 View Post
One 5955 is plenty for the Revo. Two in my opinion is senseless and not needed. Plus the benefit of a single steering servo is the servos are not fighting each other draining your battery.
Hmmm... Now there's an interesting thought - but what's the fun of that?
Sometimes it nice to have the security of a nicely ovengineered setup.
If you have read through the manual, they actually have a nice 2-page write-up on how to install the servo horns and steering links and tweak the settings.
“Everyone has a right to be stupid; some people just abuse the privilege.”
VintageMA
VintageMA's Avatar
06.18.2008, 09:10 AM
Noticed that the BEC on the stock ESC is 6volts - maybe that is why things seem a bit slow to me on the MMM.
Regarding gearing - the stock 68T spur is too big. I would like to try out the low CG mount holes, but that would never happen unless you were using a <18T pinion.
Looking into ordering a much smaller spur in the 54T - 58T range (amain has a great selection) and just got a variety of 32P pinions from Mike to experiment with.
bruce750i
bruce750i's Avatar
06.18.2008, 09:39 AM
I'm running something like 21/62 on lower cg mount, with it in the middle of the motor slide, the motor looks nice and low. no run time for testing gearing tho. might fit a 65t spur. 1700kv 6s
VintageMA
VintageMA's Avatar
06.18.2008, 09:56 AM
Looks like you are geared for just over 40mph with those specs.
More info if you can - What motor and batteries are you running?
When you get a chance to run it let us know runtime and temps and how the performance is.
bruce750i
bruce750i's Avatar
06.18.2008, 12:35 PM
Tekneu 1515 2.5D/f / FP 3700'S sure will post up some temps. Right now I don't want to scratch my new ride by driving it.
VintageMA
VintageMA's Avatar
06.18.2008, 12:48 PM
Better put on those heavier springs or it'll be on it's lid first turn you take.
I've got one of those on the side waiting, going to try it with a 3D first and go from there.
bruce750i
bruce750i's Avatar
06.18.2008, 04:05 PM
okay i did some driving on 20/58 and took some temps after ten min i got 135 motor/100 esc/95 lipos check out some videos of it http://s300.photobucket.com/albums/n...t=bb8df352.pbr and i scratched it.
VintageMA
VintageMA's Avatar
06.18.2008, 04:17 PM
and i scratched it.
Sorry - It had to happen sooner or later.
Nice ride though. What are those tires and wheels? Are they 14mm or 17mm hex?
I am amazed how cheap the Traxxas replacement parts are compared with some of the other name brands.
bruce750i
bruce750i's Avatar
06.18.2008, 04:22 PM
Badland tires on 1/2" offset dish wheels w/ TRX 17mm adapters.
VintageMA
VintageMA's Avatar
06.18.2008, 09:19 PM
Just got the batteries in the mail today. Here's a few pics of the fit.
They are TP 5000mAh 3S.
The top bulges up a little bit but I think that is because of the spring clip. The doors close smoothly without any pressure and you can still feel that there is airflow over the top of the packs through the vents from front to back.
ID:	4821   Click image for larger version
ID:	4822   Click image for larger version
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.19.2008, 12:21 AM
Looks like the perfect battery
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
bruce750i
bruce750i's Avatar
06.19.2008, 10:54 AM
The manual tells you how to remove those spring clips, but I didn't get what they were saying. With those lipos on 6s the runtime should be awsome. At lunch I'll be trying 50wt tan springs(front) 50wt black springs (back). With the all the tie rods in the inner position.(riding high) Also I'll tighten the slipper a little it got up to 145F yesterday.
Jeremy1976
06.19.2008, 11:32 AM
Sent you a pm.
mkrusedc
NeuMaxx
mkrusedc's Avatar
06.19.2008, 06:41 PM
Is this the batt?
FLIGHTPOWER EVO25-5000 3S 11.1V 25C 125A CONTINUOUS, 50C 250 AMP BURSTS DIMMENSIONS: 167MM/48.3MM/26.8MM
VintageMA
VintageMA's Avatar
06.20.2008, 11:12 AM
Originally Posted by mkrusedc View Post
Is this the batt?
It the Thunder Power eXtreme V2 5000mAh packs that I got - but since both manufacturers use the Enerland lipo cells - it is essentially the same pack.
