06.25.2008, 04:09 PM
Originally Posted by bdebde
Recommended by Neu (from another forum I believe), as I have heard this as well. Also the instruction sheet that comes with the Neu motors (you do read the instructions right?) says low timing.
exact, on the Neu website
06.25.2008, 06:00 PM
The temps are while running at my local track. I am using the standard Losi XRT (or something like that) tyres.
Here is a shot of the MMM specs
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
06.25.2008, 06:01 PM
I didn't get no instructions with my motor.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
06.25.2008, 06:23 PM
Me neither.
06.25.2008, 06:35 PM
If the value "10" on the motor timming case is the value giving in degree, i find it little high for a "d" motor. Try to put it at 0, or if you have the option "automatic timming" as on the MGM controller, put it on automatic.
06.25.2008, 06:43 PM
Thanks, ill give that a try, the 10 is what the ESC was set to and it said normal so I just left it at that
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
06.25.2008, 06:49 PM
I too was beginning to wonder where my destructions were.
Luckily I'm not the only one.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
06.25.2008, 11:04 PM
Might set it at 3 for now since it was set at 10 before and wasn't running crazy hot, see how it goes from there and still nothing change try 0
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
06.26.2008, 02:32 AM
in my experience with other motors, the timing doesnt seem to do much at all except raise temperatures. would you be able to tell the difference between 3 and 0?
hyper 8.5 pro SOLD!
Monster Max Still Working...
JR SX3
Neu 1512 2D/S
12t pinion
4800 zippy-r
XRAY xt8
MMM
Neu 1512 3D/F
11t pinion
Yip Yip Yip...
06.26.2008, 02:56 AM
That's interesting to know about the timing. Let us know what the difference is temperature wise when you drive it on the track again.
06.26.2008, 02:58 AM
I would agree with that...
Yip Yip Yip...
06.29.2008, 08:08 PM
So what was the outcome drift. Did the temps come down? I am very tempted to copy your setup.
06.29.2008, 09:58 PM
Well just got back from the track. With it a 3 degree the motor still got up to 170F and the ESC up to 128F, battery 95F - 110F. Im now going to set the timing to 0 and put the larger 15T pinion in instead of the 14T which will raise the top speed to 47mph. My local track is fairly large. I have some thicker centre diff fluid (10000, standard in roller 8ight is 5000) coming to. If that doesn't change the temp I might look at putting a fan behind the rc box which will flow air straight onto the motor and try to work out how to go more air flow to the motor. This is a great buggy to drive and once I work out how to get the motor to stay cool, im laughing
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
06.29.2008, 10:39 PM
i ran my xt8 at the track yesterday , and i ran 4 packs, i had been running 0 timing but i changed it to 12, my temps went from 165 down to 155, but i was on a track and not wot bashing, but i think it helped.......
1515 1y , 4s , 17/48
06.30.2008, 12:05 AM
Well changed to 15T pinion and timing to 0 and went down to the track and after 8 minutes again same temps as above. I thought it was running better as I perfered the 15T over the 14T but after brining it in to check the temp. I don't think I mentioned in the 1st post that I have a front cover in front of the motor to stop debris getting in the holes.
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
