MM would cog, now it won't sync with Tx
supralover72
supralover72's Avatar
MM would cog, now it won't sync with Tx - 07.20.2008, 05:01 PM
I have an airtronics MX-3 transmitter and FM micro reciever, 75mhz. I never could get it to run without cogging, but today, it was the worst ever, and all of a sudden I just lost all control. Nothing moved, nothing worked, and my Tx won't resync. Is it the radio equipment? Is there anything I can do? I've read airtronics doesn't work that well with cc.
Thanks.
Drifted Demon
07.20.2008, 05:20 PM
i also read somewhere the spektrum dont work to well with cc, been using a spekie for long time with no probs. check all your connections mate, could be a loose one. what motor are you using with the MM to cause cogging? maybe unscrew the board from the plastic base & check the borad throughly to make sure nothing's been damaged...
supralover72
07.20.2008, 05:40 PM
I'm using a fegiao 8xl. I tried it with a hitec receiver, and it syncd but I had no control and it went crazy. I'm so fed up. I wish I could just get rid of it.
azjc
07.20.2008, 06:11 PM
where do you have the Rx located? if it is to close to the esc/motor it will pick up the interference and cause problems...the
2.4 ghz SS systems are least likely to do this
supralover72
07.20.2008, 07:29 PM
It's located above the steering servo and the esc is located above the center diff.
All connections are fine.
