MMM V2 Bec 6V possible? -
08.21.2008, 02:30 PM
Im wondering if any future update allow to change voltage to 6V instead of 5.5V or is that impossible? I've always run my external bec with MM in 6V, i got better servo response and more airflow for the 5v fan since it make it spin faster.
08.21.2008, 03:02 PM
i dont really think that .5 volt could make a big difference????
Patrick has stated in the past that you can send back your MMM and they will mod it for I believe a nominal $20 to be 6v.
08.21.2008, 05:43 PM
lol, for just a few $$$ more, you could get a CCBEC, which is much more adjustable, has higher current, and won't cost additional to re-adjust it in the future if you change your mind.
08.21.2008, 05:53 PM
That's true. But, then you got all the extra weight of the CC BEC. I think it's like 8 grams or something like that...
Patrick del Castillo
President, Principle Engineer
08.21.2008, 08:01 PM
So this means that I have to send my 3 month backordered MMM once I have it (cause it still backordered) just so I can use 6V? Im on the opposite end of the world and I have to wait another 2-4weeks....I think i'll just settle for a BEC...good thing I saw this thread.....
08.21.2008, 08:52 PM
im using mine at 5.5 and do not notice a difference. but the question is WHY was this decission made to go to a lower voltage than is commonily used for racing?
08.21.2008, 09:34 PM
lol, yeah, that's a lot of weight. 8g is 0.28oz. That small amount of weight can be made up just by better ESC placement and then trimming a little off each of the motor and power wires.
Yip Yip Yip...
08.21.2008, 09:52 PM
The 5.5v of the MMM performed better then my 6v hump packs.
08.21.2008, 11:59 PM
From another forum
Originally Posted by Patrick del Castillo
Sorry guys, Joe was misinformed. The MMM has a switching BEC, but NOT the same design as the Castle BEC. It is fixed 6.0V output, and isn't adjustable.
Sorry for the confusion!
Patrick
Oh well, what's half a volt.
08.22.2008, 12:04 AM
well looks like i'll have to live with 5.5v, dont want the extra bit of ccbec weight...but im gonna put a metal wheelie bar on it instead...hehe
Im using a servo that can operate between 6-7.4V (robot servo). I don't want to end up killing the BEC unit on the MMM (not sure though if it will but that risk of waiting again is great)
08.22.2008, 12:06 AM
how do you disable the MMM bec? take out red wire too?
08.22.2008, 01:07 AM
yep. :)
08.22.2008, 01:09 AM
that's the normal way, to remove the middle red wire.
Linear Mode
