snellemin
2 KiloWatt RACER
snellemin's Avatar
09.10.2008, 03:15 AM
Argh!!! The MGM let it's magic smoke out on 6s A123 with the same setup when I pulled the trigger, right after I plugged it in. Now I have to email MGM and hope they fix it for me.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
Semi Pro
Semi Pro's Avatar
09.10.2008, 05:10 AM
that sucks, verry sick rustler, i thought my twin vxl powered 4wd rustler was over powered
snellemin
2 KiloWatt RACER
snellemin's Avatar
09.22.2008, 12:05 AM
Got the MGM replaced with the 10S ESC from Lutach. This ESC puts out more power to the wheels them the MGM did. I blew the old slipper setup, that the MGM could not melt. After some suggestions, I upgraded to the jato slipper clutch and it can't hold the power either. Current gearing is 17/56 with a tight slipper.
snellemin
2 KiloWatt RACER
snellemin's Avatar
09.22.2008, 10:14 AM
Snapped a dogbone again this morning after swapping the spring on the slipper clutch. Putting in a beefier setup today.
lutach
lutach's Avatar
09.22.2008, 10:56 AM
That might be the baddest Rustler I've seen. Man 9S1P A123 is nice .
snellemin
2 KiloWatt RACER
snellemin's Avatar
09.22.2008, 11:07 AM
Thanks to you Lutach. I have the urge to add another cell.
I peaked at 70+ Amps this morning.
bruce750i
bruce750i's Avatar
09.22.2008, 11:16 AM
I guess you need more power?
lutach
lutach's Avatar
09.22.2008, 11:22 AM
Man, you're having fun. I'm going to post something up in the ESC thread real soon and you'll see what happened at the end. The graph will tell everything . It just basically let me know the 10S ESC is very capable of powering a dragster for 2 sec. or less at a very unreal AMP rating for the 10S ESC.
lutach
lutach's Avatar
09.22.2008, 11:23 AM
How are the temps on your ESC?
snellemin
2 KiloWatt RACER
snellemin's Avatar
09.22.2008, 11:31 AM
For the little bit that I have ran the ESC for, is was slightly warm and the motor last nite was 119F I believe.
snellemin
2 KiloWatt RACER
snellemin's Avatar
09.22.2008, 01:29 PM
Just finished a run cut short by a busted up shock and snapped axle. Power is immense. Datalogger showed 126A peak and 2434 Watts.
lutach
lutach's Avatar
09.22.2008, 02:15 PM
man, I might buy a dragster to see how the ESCs does. You're having too much fun with your Rustler. I still have to finish my SSG chassis/FLM hybrid Stampede.
snellemin
2 KiloWatt RACER
snellemin's Avatar
09.22.2008, 02:31 PM
Rolling wheelies don't get old. I got too much air underneath the body causing me to cartwheel. I'll fix it up tonite. It's tons of fun now.
These were the calculated numbers
09.22.2008, 10:46 PM
What a moneypit! Too fun...
snellemin
2 KiloWatt RACER
snellemin's Avatar
10.11.2008, 11:27 PM
Lutach's ESC is kicking butt. It's dragrace worthy. It was able to pull my A123 cells down to 2V per cell(about 76C discharge).
These are the calculated peak numbers.
Here are the pics of the current setup.
