George16
Supermaxx
George16's Avatar
09.20.2008, 02:25 AM
Did you try searching in the metric section under gears? There's a drop-down menu and you can browse the "gear blanks" window for the specific blank you need. It also gives you a slection on the center bore.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
09.20.2008, 12:15 PM
I would prefer a gear with teeth, just solid so that I can machine it where necessary. sjcrss seems to be making some forward progress on the gear, so we may have more options!
SnoopMaxx
SnoopMaxx's Avatar
09.20.2008, 02:37 PM
Why buy "gear blanks" then you just have to mill the teeth your self.
Only 33T mod1 option I can fond is the steel gears
There are a vendors here in Denmark That stock those gears in mod 1
http://uk.asoma.dk/content.asp?ID=435
They also do custom work
Morten SnoopMaxx
Never to old to play
c",)
Cowboy
09.20.2008, 04:58 PM
Have you seen these guys
http://www.khkgears.co.jp/khkweb/order/main.do
It looks like they will make custom gears
09.20.2008, 06:55 PM
Looks really handy. I will have to look up the material codes and see if any are useable, such as nylon or delrin.
I am starting my own thread now for pic of what I have come up with so far.
Similar to Cowboy's nitro revo diff idea, but different. Same principle of diff support, just different gear mounting to work with the stock gear.
