TexasSP
Something, anything, nothing
TexasSP's Avatar
10.29.2008, 09:12 PM
If I spend 140+ on an rc motor it sure as hell won't be brushed.
www.cubicle101.com
10.30.2008, 01:05 AM
You got that right!!!
I may have to get a dewalt 820 and run it on 5s lipo with a MMM. See how good it really is...
Anyone know how effecient they are?
10.30.2008, 01:07 AM
You mean aside from the arcing and friction from the brushes?
10.30.2008, 01:13 AM
I think it has a built in fan... BrianG cryptonite there
You may be right, but it would be interesting to play with the "best" brushed has to offer, at least for 40 bucks...
BTW, I have the 6x6 maxx rolling now. Check the build thred!
10.30.2008, 01:16 AM
TBH, I'd use a fan if it was built into the motor, kind of like a Pletty. It's the add-on crap I'm dead-set against. Not only does it look retarded and messy, it shouldn't be needed. But if the fan was built-in, I'd see it as a little extra insurance against heat. And I hate heat more than I hate fans.
10.30.2008, 01:17 AM
Yeah, the plett fan is a really nice design. Makes the 1512 motor as capable as a 1515... I would rather not have the fan myself, but it does help alot on brushed motors.
Oppressor
10.30.2008, 11:30 AM
As per that robotwars wiki, about 81% for the old style can
http://www.robowars.org/wikka/DewaltDrivetrain
10.30.2008, 11:41 AM
Thanks, I may have to give it a try then, that rating is not much worse than a feigao!!!
Oppressor
10.30.2008, 12:28 PM
Keep in mind though that efficiency will fall faster if they are run at lower voltage.
10.30.2008, 12:32 PM
What voltage do they run the motors at? 24v?
Oppressor
10.30.2008, 02:32 PM
I believe that it's the official specs they have on that website, which mean 18v. It should run best at 5-6s.
Reading back i noted that i was wrong. I originally though that you wanted to run it on 4s. That said if i was you i would use the mamba max on 4s and run 14.4v dewalt instead of the 18v. They are 820 sized too i believe(only .2oz of difference so they should be).
They are cheaper to start with too.
http://www.robotcombat.com/products/BP396505-21.html
Of course ohm law is ohm law and they should be a bit less efficient but it shouldn't more than 1 or 2% of difference.
lydiasdad
10.30.2008, 07:59 PM
some sparks do fly, but these motors handle 24 volts well.
@lincpimp get one. If you want brushed, get the dewalt.
10.31.2008, 01:30 AM
I may still give the dewalt a try, but I think an outrunner will end up in the truck I am building. I have a 2826/12 axi that fits my gearing perfectly...
11.06.2008, 10:10 PM
Ok, so I got a dewalt motor out of an 18v drill. How do I go about removing the pinion? Looks like it is pressed on, but the gear appears to be on as far as the front bearing. I guess I can grind the gear off on each side to release it...
11.07.2008, 07:07 PM
Yeah, just grind off some teeth until the gear falls apart more or less, or grab a pinion-puller to remove it the 'proper' way... :P
