Another CORR conversion -
11.06.2008, 05:46 PM
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
"1.21 GIGAWATTS!!!"
11.06.2008, 06:02 PM
NICE!!!...i was going to convert my other 8ight roller (which i just converted into a MT or mini muggy type truck) into a CORR truck but decided to get the sc8 and convert it to brushless instead...Your CORR truck is going to look nice though..
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
11.06.2008, 06:30 PM
Hootie, thanks. The SC8 looks really nice but it is pretty pricey. I do hope to get some of those associated wheel/tires to use on my conversion. It's really hard right now to find CORR style wheels/tires that fit on a 1/8 buggy (17mm hub).
11.06.2008, 06:48 PM
That does look nice! Any plans to add bumpers?
Also, when I made my CORR, I was concerned about attaching the body mounts to the towers. I reluctantly used the tower in the rear, but it attaches fairly low to help reduce the strain. I am curious how the towers stand up to crashes. But, I suppose not too many are as bad a driver as I am. Yes, I've taken large jumps just to land smack dab on the lid!
11.06.2008, 07:00 PM
Originally Posted by Shark413
I will start work on the front bumper and nerf bars.
11.06.2008, 07:07 PM
lol, I guess I missed that.
"1.21 GIGAWATTS!!!"
11.06.2008, 07:18 PM
on horizonhobby.com they have the wheels and body on back order and i think it says mid-november so at least you won't have to wait too long however, the pre-painted and decaled body costs $63.00 but the clear body costs $45 and for 4 wheels it costs $50 a pair....so its either going to be $163 dollars spent or $145....I think the wheels and body are waaaaaay overpriced..
Losi SCTE
MMP/1410 3800kv
Dx3s
11.06.2008, 07:59 PM
Great looking conversion so far! I look forward to completion. I feel converting a Jammin x1-cr in my future, unless my 18t sells soon. :)
11.07.2008, 12:34 AM
BrianG, yes I do plan on adding bumpers. I have custom skids on the bottom of the chassis front and back which bolt on using the diff screws. Right now those skids end right at the front of the chassis, I plan making another set and extending them about an inch and angling them up slightly. The Slash bumper can then be mounted to this extenstion. I will provide pictures when I actually start working on it. As far as the body mounting to the shock towers, well they are after market towers and much stronger than stock. I feel that between the extra strength, the additional flex from the stock Slash plastic body mounts and the larger lexan Corr body should help absorb any crash damage. I also picked the shock tower as a mount because the stock buggy mount consist of a single small point on top of the steering plate. I could have used this as a mount point but I felt a single small point, which ok for a smaller/lighter buggy body would not be strong enough for the larger Corr body. We will see, still a work in progress..
11.07.2008, 06:15 AM
Actually after looking at the mounts I am not sure the Slash parts will hold up. The Slash is a much lighter vehicle. I will run it with the Slash mounts to see how they hold up, and if they break too easily I may have to make some custom mounts.
11.07.2008, 10:22 AM
Looks very nice.
11.07.2008, 03:15 PM
11.07.2008, 03:23 PM
mmmmm carbon fiber :)
11.08.2008, 06:14 AM
Well I got a little more done tonight. Finished the battery tray, added the straps, padding, velcro and bolted the tray to the chassis. The straps are held down using steel washers that have a rubber pad bonded to it, this setup holds the strap but the rubber pad prevents the washer from cutting into the velcro. I have a picture showing how a 4S NeuEnergy lipo fits and another showing how a Zippy 4S also fits, with the Neu being fatter and the Zippy being much longer. They both fit with no problems.
NeuEnergy 4S lipo pack
3M dual lock Velcro on the battery and tray keeps the battery from sliding around.
Zippy 4S lipo pack
Certified Spaceball
11.08.2008, 03:04 PM
Very Nice! Great looking build.
rcm xt8
rcm xb8
rcm crt.5
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
