11.07.2008, 11:46 PM
You could try heating up the pinion. The metals are probably not the same, so will have different expansion rates and may be easier to remove...
11.08.2008, 12:19 AM
I can try to heat it, but have no idea how to hold onto the gear. I could clamp it into the vice??? Then use a punch to tap the shaft out of the gear...
Oppressor
11.08.2008, 08:50 PM
If it was me, i would stay away from any treatment involving heat. It might undo the heat treatment that the shaft probably received hence weakening it.
11.08.2008, 11:05 PM
True, I ended up grinding the pinion on both sides and then split it with a pir of pliers. Easy when you know how...
