BlackedOutREVO
11.29.2008, 05:32 PM
I am currently running the 3.5" tires. Do you really think this will run too hot on 3s?
Yeah for 3.5 I guess you would be fine. Thats around 37mph. I dont know how far you can push a out runner yet. So I cant say what will and wont work and be 150% positive about it. But from what I have learned, they really work better with a lower KV, and higher voltage, less cogging, less heat and all
BlackedOutREVO
11.29.2008, 05:33 PM
Ok, shoot me a pm when you figure it out.
Will do!
Thanks
Metallover
RC-Monster Spudgunner
Metallover's Avatar
11.29.2008, 05:43 PM
I think this is a good comprimise 1100kv, 48mm long- http://www.hobbycity.com/hobbycity/s..._35-48_1100Kv_
It is less KV and longer. It might handle the bigger tires too.
How long is the 770kv motor on the previous page?
BlackedOutREVO
11.29.2008, 05:49 PM
Motor Dimensions: 37.4mm x 48mm
Same size?
3.25
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 1
Pinion Tooth Count: 1
Total Voltage: 11.1
Motor KV: 1100
Tire Diameter (inches): 3.5
Tire Ballooning (inches): 0
Tire Circumference (inches): 11 inches (279.29 mm)
Total Motor Speed: 12210 RPM
Vehicle Speed: 39.12 mph (62.84 km/h)
Estimated Adjusted Speed: 37 mph (60 km/h) - 5% loss
Or at 1000, its 35.6 mph
Id say either will work. But so far there have been a few conversions with the KD out runner, so thats why we ordered the KD because we know it works. Never used that other motor. So you can choose there
rcgrinch
01.06.2009, 07:11 PM
i am also liking the outrunner for my .5
what drive cups are you guys useing??
i am planning on useing the 1000kv that was posted earlyer in this thread.
any help would be great!! thanx guys.
Metallover
Metallover's Avatar
01.06.2009, 07:31 PM
I've got an updated pic. I ended up getting the 1100kv motor. I still need a 3s lipo, a battery tray and a front drive shaft. I also need to do little things like move the motor a little to the middle and get the radio box/antenna mounted.
I tried it out on 8s nimh and it had tons or torque and I got decent speed. I think it's great because I picked the outruner to run on 3-4s lipo.
