11.15.2008, 02:26 PM
3906 with 2.5r drive shafts all around ... snaps like twigs
2 x 6cell 4000mah battīs
Need 3.3 drive shaft and diff ... would that be enough ?
11.15.2008, 02:47 PM
i dont think the 2.5's or the 3.3's will be enough.. you might need somehybrid diffs for 6s, and definatley get steel idlers for the trans
11.15.2008, 02:55 PM
How ībout on 4s ? or is that to low volt ?
I only have two 6cell NiMh battīs at the moment
Iīd like to get a few set of A123 cellīs
I heard they were safer compared to some LiPoīs
11.15.2008, 03:45 PM
4s you would still need a driveline update, A123 are technically safer then lipos, but as long as you have some common sense lipo's should be fine.
11.15.2008, 03:52 PM
Thankīs
11.22.2008, 02:50 PM
How about, in "motor selector" there is vehicle weight, but is it lbs or kg or something else??
12.02.2008, 01:14 PM
If your willing to add Then cen matrix Tr, the diff ratio is 2.8888888 9/26.
Spur gear is 66t stock.
12.02.2008, 01:31 PM
Sorry, I guess I missed this question. Anyway, it's pounds.
Yeah, I can add that.
Looks like it's time for a small update. Before I go making the changes and FTP'ing everything back up, are there any other additions to make (mainly ratios and the like)?
12.02.2008, 01:35 PM
Just wanted to say that that whole site is great, it even helped me on school today!
I didn't knew what the teacher meant with Parallel and in Series, he couldn't explain it good to me, but after seeing some things on that site I get it
The only thing that could be better is more cars in the Speed Calculator.. ( More Diff ratio etc. )
- Patrick
12.02.2008, 01:39 PM
Lol, glad it helped, although I never thought it could be used as a teaching aid!
I add ratios for any car I have or am thinking of getting. Then, I add any ratios people submit. However, the ratios have to be tooth counts of the two (or more) gears, rather than the final ratio. Posted ratios are typically rounded and introduce errors in the final calculation. So, I use the tooth counts, do the math (keeping high precision), and only round the display value. So, if you have any of that info, feel free to post it!
And as a side note: I am currently working on another similar project for Mike, so any additions will help him in the long run as I will be borrowing much of the data from my site.
12.02.2008, 01:48 PM
Brian,
Your calculator is awesome. It was dead on with the speed I got from my BPP truggy. Great job.
12.02.2008, 01:49 PM
Glad to hear it! Just curious, was it the theoretical max speed, or the adjusted speed?
12.02.2008, 01:57 PM
That was the one that was dead on, 46mph.
12.02.2008, 01:59 PM
Do tell - what is the project? How can we all help?
12.02.2008, 02:10 PM
Lol, that was an either/or question. Was it the theoretical top speed (no drag estimates figured) OR was it the drag adjusted speed.
I'll have to ask Mike how much he wants publicly known first. I do know he said it was ok to get user's input on the various vehicle data. I am currently putting together a google docs spreadsheet to easily gather this data instead of sifting through posts (and we all know how topics tend to stray). I will add in what I already know and then post the result for others to add.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Linear Mode
