brushlessboy16
brushlessboy16's Avatar
12.25.2008, 04:18 PM
Thanks trev.. also got a new wing! makes the truck look pretty:)
One quirk i have found with the RCM 2s's is the not-so-standard thunderpower balance tap, I ended up taking the indidual connectors our of the TP housing and pluging them into my charger/balancer manually..
Metallover
RC-Monster Spudgunner
Metallover's Avatar
12.25.2008, 04:43 PM
Those are some nice looking lipos...
Takedown
WARNING: May become violent.
Takedown's Avatar
12.25.2008, 07:59 PM
Looks great.
RIP- Tammy (9/14/08)
brushlessboy16
12.25.2008, 08:29 PM
Thanks! Just placed the order for some odds and ends:
Battery trays
Battery straps
CA debonder
Shims
and setscrews
xirtic
01.04.2009, 10:48 AM
I just thought that I would share my Cen Matrix Buggy conversion (not fancy), but I did read someone (Brushlessboy) here thinking of what CORR Hybrid look would do to it...so here are some PICS.
ID:	6144   Click image for larger version
ID:	6145   Click image for larger version
  Send a message via Yahoo to xirtic
brushlessboy16
01.04.2009, 11:10 AM
wow that looks really good! But i have the truggy ;) Where'd you get those piggyback shock caps from?
brushlessboy16
01.04.2009, 11:17 AM
xirtic
01.04.2009, 11:21 AM
The caps were the caps from the CEN GENESIS, and a hardware kit. I got the numbers from CEN SUPPORT. I do not still have the email from them as reference. (I should keep that stuff)
brushlessboy16
01.04.2009, 11:28 AM
Were they a direct fit for the matrix?
JesseV
01.04.2009, 11:49 AM
My Matrix Buggy has now the new MEdusa 70mm 2300kV motor, its pretty amazingly better than the china motors. :D
Tests on track: (posted on medusa thread too)
Configs on MMM:
Data:
The average amp ~10A was surprisingly low imo, and the peak amp of less than 90A too. So with a Zippy 4s 5000mAh lipo I get at least 20min run time on the track. Maybe even 30min.
xirtic
01.04.2009, 12:46 PM
Yes. It was direct, and easy. As a bonus even the plastic was the same color. Makes it look factory.
I found the part numbers:
Resivoir: (2) GS233
Small Parts: (1) GS065
trev3813
Dsm needed
trev3813's Avatar
01.05.2009, 08:01 AM
Nice tires Ben, the wing looks good to, I got hole shots on my revo.
01.05.2009, 10:15 AM
Looking good dude. Why not set up the truck for saddle packs?
brushlessboy16
01.05.2009, 01:12 PM
I plan to set up for saddles. I ordered a smaller spur so I can flip the diff and put the motor up front-across from the servo. I have a second set of the losi Trays on the way (the flat bottomed onefits but the other does not) so when all the stuff arrives it will be saddled. I just need to find a place to put the Bigass MMM now...
01.05.2009, 07:49 PM
Here is what I did when I ran saddle packs (if it helps at all)
Tags
cen matrix
