11.22.2008, 02:29 PM
Originally Posted by kulangflow
Hey Linc, what's the best method you've found for using the zinc flux and solder?
I've soldered for years using Dean's solder, but I've never had to use flux and solder separately before. I'm splitting a 5s 5k Neu pack into a 3s and 2s configuration.
I'm going to look it up, but I figured I'd get your professional opinion as well.
Somehow I have missed all the posts on this thread... Whoops!
The best method I have found is to smear a small amount of the flux on the tab, then tin the end of the soldering iron with the zinc flux. When you touch the iron to the tab it will liquify the flu and the solder should flow onto the tab. I use a reasonably wide chisel tip on the iron and keep it on the tab with a swirling motion to make sure that the solder spreads evenly.
11.22.2008, 02:31 PM
Originally Posted by auto2
i have a 4s 3700 i got from mike that says anyrc.com on it that has a strange proble,
everything seems normal.pack is hard and flat,charges corrctlly and is in balance butit has no power at all. if buggy is geared for 40 mph with this pack it will go 10mph full throttle. wont even rev up enough to have trouble making full speed turns on the street it is that slow. what you think?
Do you have another lipo to try? May not even be the battery.
How do you charge the lipo? What balancer and charger do you use? Do you have a volt meter? Also what motor and esc are you using?
11.26.2008, 06:06 PM
lincpimp ygpm
01.06.2009, 11:05 AM
Just figured that I would update this thread with my recent repairs.
I have now repaired all of the various hard cased lipos. So I am familiar with how they are setup internally, and most inportantly, how to get the cases open with out damaging the case or internal wiring. So heres a list,
All losi hard cased lipos
Enerland hard case
Orion/kokam hard case
Trakpower
And the cheaper ebay chinese cell hard case lipos
Not sure that I put this anywhere else, but please post info here or pm me. I leave pricing to pms, but repairs usually take a day or so and I can ship back the lipo. Payment can be made via paypal or thru MO/cash.
And as always I am interested in buying damaged packs that you may not want, I only ask to have a look at them before we settle on a price. I will also pay shipping for this.
Thanks for all the interest, and I hope I am providing a somewhat useful service...
01.09.2009, 09:16 AM
Lincpimp really knows what he's doing. My Losi pack had died an untimely death and lincpimp was able to take the pack apart, fix it and make it stronger than it came from the factory. Thanks again for saving my pack.
01.09.2009, 07:09 PM
I bet you can't work your magic on these.
01.15.2009, 10:27 PM
No prob, you are very welcome. I can fix most problems, and will be happy to look at anything sent to me, free of charge unless you want it fixed!
01.15.2009, 10:29 PM
Looks like you have 1 good cell, bottom one on the left pack... Othwise they may be gone...
Now you can try flattening the ends back and resealing them... I have am in the process of testing this on a torn cell... I am not in the charging phase yet so try at your own risk!!!!
I will post back results...
RC-Monster Square Tube
So It Happened...... -
01.15.2009, 11:29 PM
Linc I'd like your input on this- first off, I was under the impression that the Maxamps 2S 6000 were a 2 cell, they're 4 with 2 paralleled. So my first thought is how the hell can you balance these at all with their setup
So I ran my packs down to about 7.1 on one run- not even close to cutoff, they flatten out enough that it's noticeable anyway but sure enough one is a little swelled- kinda knew it'd come with all the fun stuff I've read about Maxamps, but still it blows- especially considering I had to send 2 packs back a few months apart to GET two packs that were good. The first order one pack was at 4.2v, went back immediately, then a few months went by and the third one wouldn't balance, it was long enough that they felt the need to charge me more for the fourth replacement, so I paid around 3 bills for two packs- don't I feel smart for not finding RCM sooner..... the real issue was fitment in my mute, it was built for 6 cell packs and I had few options, but never again...
Anyway rant over, do you think this is ok to trial run? I charged it up full and it is balanced, but I wonder if it's worth trying. The other thing is these like peckmarks around the perimeter of the puffing, have you seen that alot? And the bottom cell seems very slightly puffed, should I just dispose?
01.15.2009, 11:40 PM
They are all punctured. I'm just going to trash them. Its not really worth it to try and keep them. I only paid 50 or so for the set. I might wait an see what happens to your packs though.
01.16.2009, 12:48 AM
Hmmm, your pics are not really clear enough, can you take a pic on the side of the pack so I can see how puffed the cell is?
As for paralleled cells, they will work properly if and only if they are matched correctly. Maxamps told me they matched their cells, and I say that they are full of shite. I had a tech at flightpower explain their multi step matching process...I doubt that maxcraps has anything like that.
So my advise is to sell the maxamps packs that are still good. If your setup is ok with those packs, a pair of trakpower or other decent enerland hardcase packs will do fine, even at around 5000mah. Those will outperform the maxamps 6000 packs, which are 15c packs at best.
Stay away from parallel packs, only decent ones I have seen are the true rc 8000 packs.
They most likely puffed due to over discharge, and poor matching. The weak cell in the paralleled pair could not handle the discharge amps and most likely puffed due to that.
01.16.2009, 01:22 PM
The photo on the left is the upper cell, pic may have exaggerated the puffng a bit, it's about 1/8 inch, and about half that on the lower cell.
Never Fast Enough
01.16.2009, 01:34 PM
It is likely that some of the swelling has actually gone down already. My MA packs usually swelled big, then deflated over time, only to swell again upon use. Dangerous game to play, I know. :-)
01.16.2009, 01:46 PM
It actually has stayed the same kulangflow, which is why I am (stupidly?) considering trying it, I am in denial--- these packs have less than 30 cycles on them and I have treated them like china... grrrr I don't want to put .22 holes in this pack yet!
But then I do- knowwhatImean?
01.16.2009, 02:55 PM
Well, once they puff they are done. You can try running it, but it puffed for a reason, so you will most likely puff it more.
Like I said, sell the good one, and you can send me the bad one and I can make a 3s 3000 pack out of it and then you can sell it too, or use it in something low draw. That way you can get some money back out of them.
You really need better packs, as your setup is most likely too potent for those 6000 packs.
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
