CCBEC vs. Novak HV UBEC
SidewaysLS4
CCBEC vs. Novak HV UBEC - 02.02.2009, 11:41 AM
I'm setting up my speed buggy with a MM, which has that 5 volt internal BEC. Only thing is I want 6 volts to keep my servo speed up so my gyro setup works as well as possible. I got a CCBEC already, but I neglected to notice that I would need that CClink thing to actually set it to 6 volts. So more parts required...
I read though the forums and it seems that there was some sort of issues with the CCBEC's breaking and allowing full battery voltage to the rx when this happens, scary (man I wish I researched this more, lol). So I'm now thinking about the Novak HV UBEC, 6 volts, and roughly the same price as a CClink to get the needed 6 volts. Seems to have a nice big cap on it to kill noise as well. Funny thing, Tower emailed me a $20 off $50 coupon, just in time for this
What's the word on these BEC's? Good, Bad?
emaxxnitro
emaxxnitro's Avatar
02.02.2009, 12:23 PM
The ccbec is fine. If you mount it right I doubt you will have any problems. I have 2 on my rig 1 for servos and one for fans and led's one at 6v and 1 at 9 volts
808E
himalaya
himalaya's Avatar
02.03.2009, 06:16 AM
$20 off $50 coupon ?? That's a crazy discount. as a member the best coupon I've got is $75 off $300. How can you get it?
....What a Blue Sky....
SidewaysLS4
02.03.2009, 02:08 PM
I switched email address on my account from home to work a couple weeks ago, then this 20 off 50 showed up in my home email. Described as an introductory coupon of some sort, gotta get more of 'em!
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
02.03.2009, 06:32 PM
Ima go do that too.
Area 52 Ranch Raceway
T.R.C.R.
bensf
02.03.2009, 06:39 PM
When a switching BEC fails it will let the full voltage through. Its the same for the CCBEC or the Novak BEC or any other switching bec.
himalaya
himalaya's Avatar
02.04.2009, 02:31 AM
There are many ways to fail. if the MOSFET get shorted, the situation you described will happen, but if the MOSFET get broken(none conductive), the BEC will output 0V.
jhautz
jhautz's Avatar
02.04.2009, 10:07 PM
What version on MMM do you have? The V1 I have is 5v bec ouput but the V2 and V3 both show 6v output when I test it with a meter. If you have a newer MMM its putting out 6v even though the specs say 5v. You probably dont even need the external BEC if you are only looking for 6v.
to make it...
or break it...
Silent...But Deadly
SidewaysLS4
02.05.2009, 10:04 AM
It is a MM, not MMM. 1:10 stuff.
azjc
02.05.2009, 10:24 AM
if you are concerned about a BEC failing the only way is to use a RX pack. The Heli guys use a 2s lipo pack with a voltage regulator
jhautz
jhautz's Avatar
02.05.2009, 11:05 AM
Gotcha. Didnt read close enough.
to make it...
or break it...
Silent...But Deadly
02.05.2009, 11:12 AM
If using a seperate rx pack is not desired, you can do a hybrid system. Use any switching BEC to bring down the battery voltage to 7-7.5v, and then use a linear regulator to take care of that extra 1-1.5v. Wouldn't be the best efficiency-wise, but better than using a linear regulator solely, or dealing with a possible BEC failure...
himalaya
himalaya's Avatar
02.09.2009, 07:07 AM
Good idea, that also results in lowest possible switching noise, very clean BEC output.
