03.02.2009, 11:55 PM
Originally Posted by drkros3 View Post
im looking for something with more mah for more run time. 4500mah would be less then what i already have.
im switch to the tekno kit so it should be more ballanced cause the esc and motor and brake servo are on one side and on the other side would be the battery and the stearing servo. so should be pretty ballanced.
I got ya... I will add that the true rc pack will most likely be too big to fit under the body... Kinda like a maxamps 8000 4s pack. It is huge.
Any reason that a battery swap will not work for you?
drkros3
03.03.2009, 12:17 AM
i was trying to work around swaping batterys in the pits. was kinda hopping i could find something that i would be able to run the whole time with.
my current body is the rc8e body. its a big bigger so it can hold a bigger battery. tomorrow i well find out how big of a battery i can fit under it to see if this would work.
Finnster
KillaHurtz
Finnster's Avatar
03.03.2009, 09:14 AM
It is big and heavy, 850g iirc. I still have my 3yo TRC 4S 8000 batt. I always liked it. Always performed well, never that much out of balance and has lasted a really long time. Seems a bit big for a buggy tho.
I always used it w/ an XL motor and a MM. Never blew up on me. Who knows about the MMMs tho....
jetboat
03.03.2009, 09:30 AM
need price two thank you
bruce750i
bruce750i's Avatar
03.03.2009, 11:44 AM
I have been using one with a v1 monster and a v2 monster with no problems. I bought three of the trc 8k bricks for a good buy or I would never have tried these jumbo packs, but I like them. I haven't even balanced my 4s 8ks in like 20 cycles. I do like having the piece of mind of having the longer runtime when bashing.
