What medusa to Jammin X1Crt
Kenneth Nygaard
Kenneth Nygaard's Avatar
Exclamation What medusa to Jammin X1Crt - 03.12.2009, 10:06 AM
Hello.
Are unsure about what medusa motor I should buy for my Jammin X1Crt.
I have read some in here but have not really been wiser on which one it should be.
I had first thought and buy a 80mm 2200Kv but is unsure now!
Esc is HW 150A 4-5s LiPo Pinion 14,16,18!
Hope you can help me!
Brushless X1Crt
Brushless Slash
Brushless Scrt10
Brushless Mb4
03.12.2009, 10:18 AM
The Medusa 36-80-2000 motor on 5s works great in my Xray XT8 truggy, geared 48/12. Gives me around 35mph speeds.
Kenneth Nygaard
03.12.2009, 11:42 AM
Okay, have you tried to run 4s?
My spurgear is 62T is 14T pinion fine with it.
I only have 4s currently!
Brushless X1Crt
Brushless Slash
Brushless Scrt10
Brushless Mb4
skellyo
skellyo's Avatar
03.12.2009, 11:45 AM
Yep, that's fine. That puts you at about 35mph with an average truggy sized tire. You could even go up to the 16T if you want a bit more speed on 4S (~40mph).
Kenneth Nygaard
03.12.2009, 11:53 AM
okay so 2200kv is too much
Brushless X1Crt
Brushless Slash
Brushless Scrt10
Brushless Mb4
skellyo
skellyo's Avatar
03.12.2009, 11:57 AM
No, not at all. The 2200kv will work excellent on 4S geared 14:62 (~39mph). There's really not going to be a whole lot of difference between the two motors. If you only plan on always running 4S, go with the 2200kv. If you plan on running 5S primarily, go with the 2000kv.
Kenneth Nygaard
03.12.2009, 01:42 PM
okay, if it run fine with 4s, I see no reason for 5s.
It would only be if it gave more power
Brushless X1Crt
Brushless Slash
Brushless Scrt10
Brushless Mb4
03.12.2009, 01:58 PM
%s is better than 4s. 4s in a truggy with the larger/heavier tires will require very good lipos. With 5s you can get away with a lower rated pack. I generally think that a 4s setup in a mt/truggy needs a cell capable of at least 150amps cont. On 5s you can drop down to a cell with specs around 120amps cont.
Just my 2 cents...
reel
03.12.2009, 02:09 PM
Hi
I have nearly the same question.
I drive a x1 crt with kokam 5s Lipo and 62 HZ.
Now I want to buy a Medusa, but I do not know if i have to buy the 3670 with 1600KV or the 3680 with 1600 KV.
Kenneth Nygaard
03.12.2009, 02:52 PM
Okay, my battery is a Hyperion VX 14.8 V 3700mah 25/40C
must have a LiPo more, it must be a 5s then
Brushless X1Crt
Brushless Slash
Brushless Scrt10
Brushless Mb4
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
03.12.2009, 04:39 PM
Originally Posted by reel View Post
Hi
I would be perfectly comfortable putting a 36-70-1600 in a truggy. 80mm will run a touch cooler, but the 70 should handle it just fine. I'm planning on picking upa 36-70-1600 myself in the next month or so. My Tekno Neu will be going an an E-Maxx and the Medusa in my Revo, both on 5s
Kenneth Nygaard
03.12.2009, 04:50 PM
I have now ordered a medusa 36-80 2200Kv
hope it to run well.
Brushless X1Crt
Brushless Slash
Brushless Scrt10
Brushless Mb4
Jabe
03.12.2009, 07:00 PM
I have 36-80-2200 in my truggy with 4S lipos, and gearing 14/52 and its running great, havent been able to test it on track yet.
Im going to test it with 17/52 gearing also, to see how fast it goes...
Also im thinking about upgrading my lipos to 5S or 6S for bashing, as 4S is barely enough for that.
superek4
superek4's Avatar
03.14.2009, 07:49 AM
I m running a 36x70mm 2000kv more than enough, medusa advise 70 is better for truggy 80 is for heavier trucks n is overkill in truggy drain more batt
