padrino
hmmm...
03.15.2009, 11:02 PM
Originally Posted by Finnster View Post
As far as shock oil... I'm sure KY would work perfectly well also, but I don't know why you would do that. Even lst shocks aren't that big..
Maybe not that big but what if I want to go all day long
jhautz
jhautz's Avatar
03.19.2009, 12:42 AM
Yeah just don't use it on your eyes or other sensitive parts.
thanks for that tip.
EDIT: I actually thought that CA glue was developed by the military specifically to be used as a cheap easy and quick field dressing for the wounded.
to make it...
or break it...
Silent...But Deadly
FireWire79
03.20.2009, 11:34 PM
I don't know about that, but I have been using CA glue to seal up cuts for years. I used it when I raced mountain bikes, as it was good for sealing tires and sealing boo-boos.
My wife actually got cut about a year ago. Could used a couple of stitches. I washed and prepped the wound and sealed it up with some CA. Looks better than it would have coming from the hospital. No scar or anything.
Just be sure to wash the area first, and use the CA within 1-2 hours. Press the skin together, and place the CA on top. It will bond the skin to itself and form a protective barrier that is better than a Band-Aid. Its also waterproof. If it starts to come off, just reapply and your good to go.
jhautz
jhautz's Avatar
03.21.2009, 12:05 AM
The straight dope....
http://www.straightdope.com/columns/...nds-in-vietnam
to make it...
or break it...
Silent...But Deadly
