snellemin
2 KiloWatt RACER
snellemin's Avatar
03.29.2009, 07:50 PM
Originally Posted by phatmonk View Post
The body vibrates alot at high speed but its pretty easy controling it compared to a 1/10 car.
I too find the 1/8 easier to control at higher speeds. Just got to save up a bit for new diffs and the slipperential.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
tashpop
03.29.2009, 08:37 PM
you guys just need more power and the 1/8th's will handle like crap lol....
its good news its closer now. i need to get a pinion gear or switch to 1 speed, and a radio in it. i sold my 3pks, but now i wish i didn't. other than that, its ready to go.
what top speed are you geared to?
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
snellemin
2 KiloWatt RACER
snellemin's Avatar
03.29.2009, 09:04 PM
I remember yours endlessly doing 4 wheel burnouts.
I'm geared for 50mph or so, but it sures comes at you fast. I'm liking the 10s A123 setup, as I peak at 88amps at around 2034Watts. Way more play time now.
phatmonk
RC carbon junkie
phatmonk's Avatar
04.15.2009, 04:38 PM
Hey guys I have finished my Carbon Fiber chassis.It came out great.The original chassis is offset to one side so I made the CF chassis symetrical.It was actualy pretty easy I used a jig saw to cut it out and countersank all the screws.I also picked up a Neu 1515.5y/s new for 200.00 bucks.Put a Losi heatsink on it and run it on 3s.Its fast!!!!!!!!!!!!!!!.
ID:	6822   Click image for larger version
ID:	6823   Click image for larger version
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
snellemin
2 KiloWatt RACER
snellemin's Avatar
04.15.2009, 04:44 PM
Great job on that chassis man. Makes me wanna have one too.
bdebde
That's All Folks!
bdebde's Avatar
04.15.2009, 08:54 PM
Nice CF chassis! Any idea how much weight it saved? So no problems with fraying /seperation from cutting the CF with the jig saw?
phatmonk
RC carbon junkie
phatmonk's Avatar
04.15.2009, 09:13 PM
I bought a 1507 model Bosch jig saw and the best metal cutting blades I think they are 20tpi.No seperation problems.I got the plate from Dragonplate 1/8 inch 3.17mm 15 layer carbon fiber.I put the smooth side up and the textured side down then finished the bottom with 15 coats of polyurethane sanded with steel wool.At first I tried using my 20 year old BD jig saw and it did overheat the cf that made it seperate.The Bosch jigsaw made the differance that made it possible.I did tester pieces to make sure that it would work before I even started the chassis along with testing countersinks.I am going to do another chassis in SSg 4mm silver graphite next.
As for the weight savings that wasnt realy a issue I wanted a chassis purpose built for electric.Its wider than the original and no extra holes with organized battery mounting holes.
