Raze
jrandolph7002
Raze - 05.04.2009, 07:34 PM
I HAVE A DUMB QUESTION....I'M LOST I GOT THE BATTERY TRAY FROM MIKE TODAY...I HAVE NO CLUE HOW TO ATTACH THE TRAY...I HAVE TO DRILL...OR DO I MATCH IT UP TO SOMETHING......THE TRAY HAS A RASIED AND A LOWERED AREA...HOW DO I MATCH IT UP...SORRY I JUST BIT OFF MORE THAN I CAN CHEW..
05.04.2009, 08:42 PM
You should have 2 pieces...the tray itself and a bottom piece. The way I mounted it was by taking the bottom piece, placing it on the chassis where you like it, clamp it to the chassis to hold it in place. Then drill 4 holes thru the plastic and the chassis. These are your mounting holes. You will need to counter sink the holes on the bottom of the chassis. Next, I took the tray itself and screwed it to the plastic bottom piece. You will need a piece of foam or such to put in the bottom of the tray to keep the batts. from hitting on the screw heads.
Some of the trays I have gotten from Mike are just one piece so just line up where you want the tray, drill, countersink the chassis holes and you are done! The velcro straps fit nicely between the tray and the chassis or between the bottom piece due to the nice groves Mike provides us with.
Good luck...and really it is quite easy, just take your time
jrandolph7002
05.04.2009, 08:53 PM
mine looks like the one on page 2 with out clicking the item..its a one peice..the tray has 2 deffrent levels it would have been better if it was flat...its not..thats what makes it harder. and confuse's me.3/4 in deep and maybe 3/16 deep along the whole tray...any way i will try...it just wont sit flat..
05.04.2009, 09:01 PM
Your tray should look like this....correct?
http://www.rc-monster.com/proddetail...erytray&cat=18
05.04.2009, 09:05 PM
You received the one designed so that part of the tray sits on the mudguard and the cut out on the bottom is designed to clear the screws which attach the mudguard to the chassis
jrandolph7002
05.04.2009, 10:53 PM
yep the pic on the page 2 is it.....not the link you sent....i cant link it...
but yea that does make sense....yep i do i attach this to the buggy now...
jrandolph7002
05.04.2009, 11:44 PM
i get it never mind
