TexasSP
Something, anything, nothing
TexasSP's Avatar
05.10.2009, 10:40 PM
Like nitrostarter said, something has to be wrong in your setup to kill two neu's in a row like that. Either something seriously jacked in the drivetrain or you are getting dirt inside the motor.
www.cubicle101.com
nitrostarter
nitrostarter's Avatar
05.10.2009, 10:49 PM
How is your gear mesh? A proper gear mesh is key!!!!!!!!!!!!!! Too tight and it will cause these motors to over heat and possibly fry the windings like seen here.
N. Rustler conversion
emaxxnitro
emaxxnitro's Avatar
05.10.2009, 10:51 PM
it might have been on the snug side. but paper fits between the mesh just fine.
this could very well be my problem.
808E
Neu
transtalon
Neu - 05.10.2009, 10:52 PM
I just tried a 1515 2200 kv yesterday in a Lst2 with a big CEN Genesis wheels,
MGM 22418 ESC, 6S 8k M.A. lipos. I combine the gearing with a 63 spur and 30 pinion and it's still pulling wheelies but I notice it wasn't as fast as with a LPR MT tires. I put the stock 25 pinion and the motor only reach a 120 degrees. The truck weights about 15 lbs with the CEN wheels on. This motor is more powerful and heat less than my 80mm 2000kv Medusa. I'm surprised you aren't having goodluck with that motor. I own three Neu including a 1527 and it performs flawless.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
Originally Posted by emaxxnitro View Post
1515 1y. its the same problem as before. im tired of the terrible reliability of this motor. to fry in my front yard is one thing but to fry on a track with 5 nitros against you is just plain embarrassing.
Man if it happened twice, it's all you. If Neu repairs it this time, try plugging those holes. It looks like the bearing is gone, too.
DwightSchrute
I'm obsessed with The Office
DwightSchrute's Avatar
05.10.2009, 11:54 PM
what esc are you using?
8IGHT 2.0 2650KV MMP
LOSI TEN SCTE NOVAK 3700 MMP
B44 MMP TRINITY D3 6T
B4 MMP TRINITY D3 9.5
E-REVO BRUSHLESS EDITION
Patrick
Patrick's Avatar
05.11.2009, 05:28 AM
If the wire was broken then it sounds like it's been bent back and forward too much, or not been supported enough and bounced around while driving. Those wires are fairly brittle and don't like much movement at all.
My 1515 1y is all most a year old and hasn't had any problems, so it's pretty unlucky to burn 2 off them.
big greg
05.11.2009, 01:01 PM
+1 i was just gonna state that, i alway tie wrap my wires together and also to a post or something, AND put hard foam underneath the wires exiting the can, what ive done lately is layer up shrink wrap till its snug against the holes. BAM no flex, do you have pics of the wiring before the burn?
emaxxnitro
emaxxnitro's Avatar
05.11.2009, 05:00 PM
no i have them supported with heat shrink and made sure not to bend them.
808E
chilledoutuk
05.11.2009, 05:36 PM
from the picture it looks like you have tied the 3 cables together from the way they are bent towards each other, even the grommets have been displaced from this.
I think you should try using a castle-neu motor as its better designed for the rigours of rc and i doubt you would break it as easily.
emaxxnitro
emaxxnitro's Avatar
05.11.2009, 07:15 PM
hey nobodys perfect
yeah i will send it in and if its money to replace i will make it a 1521 1y f
808E
emaxxnitro
emaxxnitro's Avatar
05.11.2009, 11:00 PM
i now have reason to believe that my mamba max killed my neu. i updated the firmware right before the run. and when i plug in my feiago all i get is cogging. i down graded the firm ware and it works fine. funny.
808E
