I just got a muggy roller
Urgeoner
Urgeoner's Avatar
I just got a muggy roller - 05.13.2009, 10:49 PM
yea! sh!t's tight It came with the aluminum f/r differential cases also
Are the front and rear diffs supposed to be a little loose in the bulkheads because whenever I spin the wheels they are moving a little bit.
Semi Pro
Semi Pro's Avatar
05.14.2009, 03:55 AM
no, you need to shim them
05.14.2009, 10:19 AM
The diff cases are a little slack on my muggy. As long as the diffs are properly shimmed inside you should be fine.
bdebde
That's All Folks!
bdebde's Avatar
05.14.2009, 03:11 PM
I put one wrap of electrical tape in there to take up the slack.
Urgeoner
Urgeoner's Avatar
05.14.2009, 11:23 PM
ya I put some lexan in between the sliding parts and the bumpers and its holding up well. thanks all! I think that the bearings for the input gear shafts on both diffs need to be replaced because they have a bit of play in them, but it also came with the aftermarket (titanium?) ring gears and heard that they are pretty tough.
Urgeoner
Urgeoner's Avatar
05.15.2009, 01:43 AM
anybody know a descent cheap motor for the truggy?
Urgeoner
Urgeoner's Avatar
05.16.2009, 01:24 PM
heres some pics I added the chassis brace so far:
