05.13.2009, 11:06 AM
I can't give you a technical explanation, but partial loads on the esc are what heat it up. Allowing the esc to be "wide open" and just flow power is less stressful on it. Turning down your epa effectively makes your esc a partial load at alll times and isn't good for it. I wish I could give you technical terms and what not, but this is my farmboy answer.
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.13.2009, 11:13 AM
Sums it up pretty well in my opinion, although I liked the vette analogy better. :D
I would go over to the 2000 kv 80mm medusa first. Or if you have the money the 1521 series neu.
www.cubicle101.com
05.13.2009, 03:20 PM
Why does an ESC run cooler at WOT than at partial throttle? Simple; fewer on/off pulses. To get variable power, the FETs switch on and off. However, a FET does not switch on and off instantly - there is a ramp up and down. This ramping is where the power is lost as heat. When at partial throttle, the ESC sends more of the on/off pulses to limit the average voltage. Think of it this way, if the ESC is 10% of the time "on" and 90% of the time "off", the motor will see an average of 10% of the battery voltage. At WOT, the ESC is sending full battery voltage, so there are no on/off switching cycles (well, not counting the switching between the phases).
I hope that made sense.
FYI, there is no difference between setting the EPA at something less than 100% and not using the full throttle trigger throw. So, you can have the EPA set at 100%, but if you are only using 1/2 the throttle trigger throw, it's the same amount of losses as setting the EPA at 50% and using full trigger throw.
If the setup is too fast, reduce gearing (will increase torque), get a lower kv motor (may increase torque), or reduce battery voltage.
littlegiant
05.14.2009, 06:13 AM
Hi there. thanks for the explaination. Correct me if I am wrong. So you mean that there is some actual pwm switching of the fets when powering each phase to vary the power delivered to each motor phase right? Doesn't the esc just rotate the magnetic field to get variable speeds by just switching the fets just on and off without pwm?
05.14.2009, 09:54 AM
Yes, there are two stages of FET switching. One stage is the rotation of the magnetic field, but then those are PWM chopped to regulate the power.
littlegiant
05.14.2009, 10:15 AM
Oh I see. That explains everything. Thanks alot really.
