Semi Pro
Semi Pro's Avatar
05.14.2009, 03:49 AM
What are the options for beefing up the GTP's diffs?
hot bodies hardened gears, aluminum diff cups and heavy duty outputs
More carbon fiber parts...
Big House
Big House's Avatar
More carbon fiber parts... - 05.27.2009, 08:33 AM
Sitting around with a little time on my hands, since I completed the CF top place and servo plate, I decided to take it a bit further and cut out the front and rear shock towers. These came out great considering the work was done using a hacksaw and an assortment of dremel bits. Here are the stock aluminum and the CF parts side by side and installed on the car.
Name:	rear shock tower installed.jpg
ID:	7147   Click image for larger version
Name:	Front tower.jpg
ID:	7148   Click image for larger version
Name:	front shock tower installed.jpg
Name:	Rear tower.jpg
bdebde
That's All Folks!
bdebde's Avatar
05.27.2009, 09:55 AM
Nice! What is the weight difference with all CF?
Big House
Big House's Avatar
05.27.2009, 06:04 PM
After the chassis is replaced, the weight reduction should be about 2 lbs.
05.27.2009, 06:07 PM
Not bad at all! 2lbs on a ~8lb car (loaded) is a savings of 25%. Good job!
phatmonk
RC carbon junkie
phatmonk's Avatar
05.27.2009, 06:08 PM
Looks awesome great job.Those small pieces are a bitch to get perfect.How thick are they?
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
Big House
Big House's Avatar
05.27.2009, 06:17 PM
Yes Monk they are. And you run the risk of wasting a lot of material. Carbon fiber ain't cheap.
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
05.27.2009, 06:31 PM
Veryy Niiiceeee......
The GTP build continues
Big House
Big House's Avatar
The GTP build continues - 07.12.2009, 08:33 PM
After an exhaustive search to locate a hobby shop that carries Ofna's DM-1 wheel, I finally found them. I go them installed with matching hud caps. The black on black look is beast. The black carbon chassis is next. Then I can focus on the powerplant and battery.
Name:	GTP II small.JPG
ID:	7418   Click image for larger version
Name:	GTP II small 2.JPG
07.13.2009, 11:45 AM
Lovin it blacked out like that. What's your powerplant going to be?
Big House
Big House's Avatar
07.13.2009, 05:48 PM
Mamba Monster 2200 on 6s.
07.13.2009, 05:53 PM
Oh.... You're so unique!
Big House
Big House's Avatar
07.13.2009, 07:34 PM
I trust Castle...but I like Medusa also. No need to be different. Just want to be fast...and managable.
07.13.2009, 07:50 PM
Wow nice job w/the cf and keep the updates coming...can't wait to see a vid! I so want one of these, but I need to sell a few that I am not using first!
Big House
Big House's Avatar
07.13.2009, 08:54 PM
Thanks...I am ordering the CF sheet for the chassis tomorrow. That will be the weekend project.
