06.15.2009, 02:13 PM
The motor I'm using is rated for 12v, plus the gear ratio I'd need for higher voltage is just not available.
06.15.2009, 03:33 PM
Anyone else?
johnrobholmes
johnrobholmes's Avatar
06.15.2009, 03:50 PM
What is this monster motor you plan to use? A 12v system is likely to fry at low rpm if you are wanting any decent power.
Gear ratio is always the problem, which is why I use hub motors. But, I have one of these coming that will make a Nue 1915 1y hit the perfect speed on a 26" bike.
Name:	dual stage.jpg
---JRH---
06.15.2009, 03:54 PM
It's a CIM FIRST robotics motor. I'd like to use 24v 10Ah but don't really want another reduction...
PS that gearbox is very cool
johnrobholmes
06.15.2009, 03:56 PM
I added some info to my last post.
Give it a shot, but it probably won't do too well on acceleration. Maybe lace your rear into a 20" rim to get more reduction? The delrin gear will probably wear fast too.
---JRH---
06.15.2009, 03:57 PM
Sent you an IM. But you replied... Wow quick!
brushlessboy16
brushlessboy16's Avatar
06.15.2009, 04:12 PM
the acetyl gears will hold up fine- we use them on our robot and they work fine without wear.
pb4ugo
06.15.2009, 06:09 PM
I'm worried about the Mod1 reduction gearing--I can't see it holding up to 200lbs of rider and bike--even though the reduction will lessen the direct torque applied to it. Can you find a mod2 combo that will work?
johnrobholmes
06.16.2009, 01:06 AM
I will be riding some mod1 gears here soon. We will see how they hold. The problem was finding mod1.5 or 2 gears for a 5mm shaft.
it will be interested to see how the ebike world changes in the next few years.
---JRH---
