What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
06.26.2009, 12:13 PM
So it's only wire thats makes up the stator in a slotless, hence no magnetic pull in any direction ( no notchy feel )
Yes. There is no steel in the stator of a slotless motor so there is nowhere for the rotor poles to "latch on".
06.26.2009, 12:17 PM
Yes, wire and some dividers(structure) I believe. IIRC, the coils are overlapped slightly differently as well, but don't quote me on that.
There is a "core" in a slotless stator as well, but it's a long toroid against the motor can, kinda in the shape of a long donut. You can kinda see what I'm talking about in the pic I took of a Feigao I cut in half:
What's_nitro?
06.26.2009, 12:23 PM
Yeah the core is there to keep the EMF from the motor from frying all the electrics in your truck. It concentrates the magnetic field from the stator in the area of the rotor magnets. In addition to protecting the devices around it it make the motor more efficient and powerful.
zeropointbug
Z-Pinch racer
zeropointbug's Avatar
06.26.2009, 12:49 PM
Good point BrianG... I should have known there would be some sort of shield/magnetic intensifying ring in there.
pinkpanda3310
pinkpanda3310's Avatar
06.26.2009, 03:13 PM
And on a slotted motor the laminated steel also acts as an emf container. So if the slotted stator was cut into individual stators the efficiency would decrease and also affect the other electric components near it.
Crikey I knew I was not electrically minded (not that way) but that never even crossed my mind
