07.15.2009, 09:46 PM
Originally Posted by Chadworkz
As long as you use an end-mill bit, because a drill bit won't work...and you better have a hand that is as steady as a robot, because you are making the hole deeper, not larger, and if you aren't robot steady you will mess up the diameter of the hole.
it'd be no different or harder than drilling any peice in a drill press. set the peice, set the depth stop, pull the lever. no computers or "robots" necessary.
UE Supermaxx Addict!
07.15.2009, 10:10 PM
Yea, it can be done with a drill-press, but not with a Dremel. However, I would just use a 1mm thinner bearing, heh.
-Chad
› PM ME IF YOU HAVE THE BELOW:
› VBS, CVDs, GM Single-Speed, OTB, Ultramaxxed, Super6, Strobe, Sprong, CNR Brake, UE Hex, DUH Towers, Predator, Blackbird, GA Blue Screws, HCR F/R Skids & Mutant
07.15.2009, 10:47 PM
HeY check this out I'm grinding the gear itself down and it seems to be working!
But on another note, I hate my dremel its nicd!!!!! Like 4 volts!! feels cheap, plasticy, like a toy! It last for like 3 mins! Takes like 3 hours to charge! AHHH! Does anybody have the lithium ion one? I lust after that thing!!! It will be mine soon! HAHAHA... LOL
RCM members are the greatest by the way.
07.15.2009, 10:58 PM
Don't get the li-ion dremel. It is terrible. Just get a plugin one.
07.15.2009, 11:13 PM
Howdie friend! I like the profile picture! What do you mean? Anything is better than 4v nicd!!! Have you owned it? I really like being portable.
Supermaxx
07.16.2009, 12:49 AM
I vote for a plug-in dremel. My wife bought me one back in 2002 and it's still working like new.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
07.16.2009, 12:53 AM
Another vote for the plug-in. I chose to get the plug-in over the battery one because it is always working when you need it, no batteries to worry about. I don't know for sure, but it seems to me that you'd get more torque out of a plug-in model as well. Mine's a 300 series and very gutless but there's no voltage drop when plugged into house current.
Supermaxx
07.16.2009, 01:06 AM
Yes, you do get more torque with a plug-in. I have an inverter in my 1:1 car so no problems taking the Dremel with me anywhere.
Revo with OS .18TZ
07.16.2009, 01:17 AM
I love my plug-in Dremel...I also have a cordless version, but I never use it.
-Chad
07.16.2009, 11:42 AM
Another +1 for plug-in dremels. If you want portable, then get the flex-shaft adaptor, you can move around alot more with it that way. Having a battery operated one isnt worth squat diddly if it only lasts a few minutes and hasnt got much power, and who takes a dremel with them when they go bashing/racing anyway? Not many people I imagine...
07.16.2009, 12:22 PM
HERE is the dremel I'm talking about. But they make it sound so awesome!
HERE is the piece of junk I have now.
But maybe you guys are right about the plugin
07.16.2009, 02:13 PM
Yes, I have used the li-ion. It is so weak I can put my finger on the edge of the cutting wheel and stop the dremel at full speed without getting cut...
07.16.2009, 02:33 PM
Yeah man sounds like good advice and all but I've cut myself on accident a few time with mine. And its 7.2v 20,000rpms. Maybe you left out some detail like it wasn't on or something...
07.16.2009, 02:49 PM
what about making it a "project x"-Dremel by adding some more volts?
I did that with my old cordless screwdriver... with my girls's cordless vacuum cleaner (adding more and better nimh's) and with my acoms hayabusa by replacing batts with a crappy 3s-lipo (-->see project x).
more volts - more fun
flo
07.16.2009, 02:53 PM
It was on.... I think my charger may have been bad possibly, there's no way dremel would market a product that you can stop with your finger.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Linear Mode
