Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
brushlessboy16
brushlessboy16's Avatar
07.21.2009, 11:33 AM
Originally Posted by KaztheMinotaur View Post
Here you go. Shown with a crank case bearing from a 30.5cc engine.
Look at that beautiful hand
nitrostarter
nitrostarter's Avatar
07.21.2009, 11:55 AM
Originally Posted by finfin View Post
one question.
Does phoenix hv 110 be enough with Neu 2215 2y and 12s A123 ?
I hope you plan on running 2p or 3p setups with those A123's...
I would ditch them and get some high discharge lipo's...
N. Rustler conversion
finfin
07.21.2009, 12:30 PM
12s2p
hv 110 can use with neu 2215 2y or not?
nitrostarter
07.21.2009, 12:45 PM
Surely can. Gear appropriately.
Ryu James
Ryu James's Avatar
07.21.2009, 01:21 PM
I got my 2215 today and "it's so big !"
nice Kaz,
what parts were you trying to sell on ebay again? you should list them again. they will sell eventually. would love to see you do a conversion also now that you got the motor.
Jammin SCRT10 Neu 1512 1y
aqwut
Brushless Heavy Weight....
aqwut's Avatar
07.21.2009, 03:15 PM
one question.
Sure would be, but you'd have to get one with a low KV...
Motor looks nice Kaz...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
KaztheMinotaur
KaztheMinotaur's Avatar
07.21.2009, 04:26 PM
Center ring and pinion, gas tank, and upgrade kit gear plate.
I'm selling my LST2, 1515/1Y, and MMM now also.
I found these motor mounts. I might go with them.
http://www.southriverrcboats.com/sho...3DWRP-B-358%26
nitrostarter
07.21.2009, 04:37 PM
Boat mounts! they should work great! And you can mount them anywhere.
Ryu James
Ryu James's Avatar
07.21.2009, 05:46 PM
cool. i have seen those. OSE sells them too: http://www.offshoreelectrics.com/pro...jwr-mount-flat
you can get them for 15xx or 22xx series. i cant remember who tried them but someone here on the forum had tried them and said they werent the greatest but i think they should hold. it says the 22xx series mount is .33" thick.
i hope you get your stuff sold soon. i have so much stuff up for sale right now too. i am selling all those rampage parts i got on ebay. there was only a couple of things i needed.
so i just finished getting all the shocks done. now i have a complete set of Baja shocks on my Ramp. they are so smooth and supple. for the rear i just used a set of baja fronts straight up. for the fronts i had to cut about 12mm off the shock body and shaft. .then i made the shaft use e-clips to hold the piston instead of a nut. i think it will hold up. but i just love how these shocks feel with the petroleum oil instead of silicone.
baja shock shaft before:
redcat44
after modding:
redcat45
Photobucket
redcat42
had to grind away just a tiny bit of the a-arms on the front and rear for the baja shocks to freely move.
redcat41
redcat40
07.21.2009, 06:01 PM
I have 2 pair of those boat motor mounts for 15 series neu motors. Not too bad, but I am not sure if I would use them in a car, not the strongest thing I have seem.
That being said if anyone wants them I will sell em off, no use for them.
Ryu James
Ryu James's Avatar
07.21.2009, 06:57 PM
send a pm to kaz and ask him. he was looking at them.
btw, you would most likely still want to build some mounting plates in order for this mount to work so you can adjust mesh. otherwise you would need to cut a elongated holes in your chassis.
what did you do linc? did you ever use the mount?
07.21.2009, 07:41 PM
Nope, was going to use them in the baja conversion, but decided that I do not really like 2wd.
I will drop kaz a line, but he needs some 22 series mounts. I think...
The redcat is looking good Ryu, I look forward to your progress.
KaztheMinotaur
07.21.2009, 08:23 PM
I think I will just go with a thick piece of angle aluminum for a motor mount.
07.21.2009, 08:53 PM
Probably for the best. I would make some sort of rear motor support though.
KaztheMinotaur
07.21.2009, 10:15 PM
Do you think it necessary with 4 mounting bolts?
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
