Need help programming MGM esc!
Page 2 of 2
Over_revO
07.24.2009, 06:13 AM
Ok thx for the info on the cell,
It do run when setup on automatic 78% , but will hit the cut-off, but running just one 4S is fine, no matter wich one i use...
Is there an easy way to test the amp on the cells?
we tested to reverse the wire, controller, nothing worked :(
thx
Over_revO
Find all posts by Over_revO
17
a6m532
07.24.2009, 09:59 AM
Hi,
You should be able to read the max current from the software use to set the parameter of the controller. b2 setting should be set to zero.
a6m532
Find all posts by a6m532
18
bdebde
That's All Folks!
07.25.2009, 01:03 AM
Check (or replace) whatever series adapter/connector you are using.
Ve8 - MMM, Neu 1509/2.5y, 6s
D8T - MMM, Neu 1515/2.5D, 6s
Muggy - MMM, CC 1520/1Y, 6s
SC10 4X4
bdebde
Find all posts by bdebde
Page 2 of 2
Linear Mode
Switch to Threaded Mode
5 : Excellent
4 : Good
3 : Average
2 : Bad
1 : Terrible
