Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
TwzteD
Live Fast, Die Early
TwzteD's Avatar
05.16.2009, 03:57 PM
i burt that kb up so i had to get rid of it!
  Send a message via AIM to TwzteD
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.16.2009, 10:44 PM
Glad I could take it off your hands too. That was an excellent transaction.
conventional wisdom would say thats too much speed for that heavy of a truck. but that system is in a savage and geared for 60mph, so it just may work. I say try it and check temps often. maybe we're all being too conservative
I agree. I will keep my trusty temp gun with me to try it out. I really wanted to gear it around 50.
I may just put the 2.5d in there and see what it does as well. It show 45 which seems like it would be a stretch for that motor in that truck as well. Anyone know what the new savage flux weighs?
www.cubicle101.com
TwzteD
TwzteD's Avatar
05.16.2009, 10:56 PM
Thanks You Too!
05.16.2009, 11:37 PM
Originally Posted by TexasSP View Post
Hey James, what do you think would be a reasonable speed range to gear for in the LST2 using a CC Neu 2200 on 6s? I am looking at lowest to highest speed.
I just ordered the TDR motor mount then saw the 20t pinion I planned using may not work with the mount. So if I am stuck with the 25t pinion that puts me at 60 mph with the big joes that are on it. Do you think this is too much considering the weight of the truck?
DO you plan to run a 63t spur? I am using a 23t pinion right now and looks like I could go down to a 22t, maybe a 21. The 2200 on 6s will be a bit high to gear under 50mph with the 63t spur. You could try to use the 70t spur...
The lst can handle speed well. just make sure you have sway bars.
TexasSP
TexasSP's Avatar
05.17.2009, 12:08 AM
Thanks, I had thought the 63t was the biggest spur for the LST2. Although looking at the 70t spur it looks as though it will not work with the TDR single speed hub. I looked and realized the 22t pinion and 66t spur will put me right at 50. My main concern is not the speed as much as can the motor handle moving it.
www.cubicle101.com
05.17.2009, 12:24 AM
I recently had a cc2200 in a savage geared for 50+ on 5s lipo and it did fine. The savage was having issues, but the tires were not balanced.
The 70t may not work with the tdr hub, never tried to fit it on.
TexasSP
TexasSP's Avatar
05.17.2009, 09:40 AM
I will try first with the thing geared at 60. If temps come in too high I will get the 66t spur and 22t pinion. All the feedback I have heard on the CC 2200 has been good so I will keep my hopes up.
www.cubicle101.com
drkdgglr
08.31.2009, 09:40 AM
After that I swapped the gears in the tranny to get a slighly higher ratio. Simple mod, requires slight clearancing on the inside of the trans case. Completely reversible too. Basically threre are 2 gears in the tranny, a 22t and a 23t, I swaped them to help out my slower turning motor (1500kv on 6s) get to 40mph with my available gearing choices.
you can now also use the lst xxl output gears to get almost the same reduction as the swap mod (swap mod 1,89 / xxl gears 1,91). the output gears in the xxl are 29/16 (losb3119). the output gears in the lst2 are 30/15.
you can also do both: swap mod&xxl output gears (1,73 reduction)
jzemaxx
08.31.2009, 12:30 PM
Any of you guys racing the LST2's??
I was watching this video of a LST2....and I was amazed. Heck I don't think my Revo could handle that well.
http://www.youtube.com/watch?v=jaJpZt4X9Bs
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
Kcaz25
Kcaz25's Avatar
08.31.2009, 01:23 PM
The driver has excellent jump placement skills( judges the how far to jump and where to land very well) plus I think those huge shocks really help.
jzemaxx
08.31.2009, 01:24 PM
Looks like its not your ordinary stock LST2....
http://www.forum.losi.com/showpost.p...73&postcount=9
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
Kcaz25
Kcaz25's Avatar
08.31.2009, 01:30 PM
Oh yeah you're right. Wish I could see the pics in the losi forum. Thats not enough of a reason to join though.
jzemaxx
08.31.2009, 01:41 PM
Here is the pics posted....
Name:	09 nats 004.jpg
ID:	7639   Click image for larger version
Name:	Custom BB Shocks 001.jpg
ID:	7640   Click image for larger version
Name:	Custom BB Shocks 002.jpg
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
TexasSP
TexasSP's Avatar
08.31.2009, 03:13 PM
Having both the LST2 and Revo I truely believe set up properly the LST2 could out handle the revo. It definitely handles rough terrain better by far. I feel that sometimes the revo has too many tuning options making it a pain to get right as well.
www.cubicle101.com
jzemaxx
08.31.2009, 03:17 PM
The one above definitely shows the capability of a LST2 setup to race.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
