Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
ta_man
09.11.2009, 07:20 PM
Yah Fox, i'll make drill it on a lath, so it'll be realy precise.
And you just give me an idea about de heat shrink, i'll put heat shrink on the axle, mesure it and drill the adapter to fit over the shrink
And when the wheel start to take some slack because the shrink start to desintegrate, i'll only remove the old shrink and put new one
Thank you Fox
And i've no digicam to make video but a friend of me have one, so i'll ask him to make the video
If you are going to drill out the adapters anyway a better solution would be to get some K&S brass tubing one size too small to fit over the axle. Cut a piece long enough to fit inside the adapter then slit the tubing lengthwise so it can expand to fit over the axle. Then you can drill (or better: ream) the adapter to fit exactly over the brass tubing (which will not disintegrate over time).
Or you could wait for adapters that fit properly.
david lamontagn
09.11.2009, 07:41 PM
Is the K&S is the tubing that we can buy at LHS in the plane section?
Thank you for the good tips
david lamontagn
09.11.2009, 08:03 PM
I have find it at tower hobbies
http://www3.towerhobbies.com/cgi-bin...?&I=LXR826&P=7
The crt.5 axle diameter is 0.1875".
the 7/32 brass tubing have an outer diameter = 0.21875", with a wall of 0.014" (x2 to have the total wall tickness).
So 0.21875" - (2 x 0.014") = 0.19075" is the insinde diameter of brass tubing.
The gap between the inside brass tubing and outer axle diameter will be:
0.19075" - 0.1875 = 0.00325" (0.08255mm) i'am sure that all the slop will be eliminated
The only thing i'll have to do will be to put the adapter on the lathe and ream it to 0.21865" and press fit the brass tubing in the adapter with a dab of green lock-tite. And drill the hole for the lock pin
Foxracin
09.11.2009, 09:32 PM
One more thing. The Slash adapters have a different offset for the fronts and rear so you need the same one either front or rear all the way around for it to be the same width.
david lamontagn
09.11.2009, 10:10 PM
Yes, i've order 2 set of front one, the larger one
Foxracin
09.11.2009, 11:37 PM
Good deal. Just making sure your were aware.
david lamontagn
09.12.2009, 12:00 AM
Yes, thank you Fox
Foxracin
09.12.2009, 09:37 AM
No problem.
ta_man
09.12.2009, 10:38 AM
I think you would be better of getting the 3/16 O.D. brass tubing and slitting it as I suggested. You would be surprised how much wobble that .00325 of play will translate to at the outer edge of the tire. With the "one size smaller" tubing you can eliminate all the play. Also keep in mind that the dimensions on the K&S tubing are "nominal" and could vary a few thousandths, leaving you with more slop that you expect.
If you didn't already know, you can order custom size reamers from McMaster-Carr (www.mcmaster.com) in half-thou increments.
justpassedu
10.26.2009, 10:18 AM
if anyone would like my adapters and mohawk 17mm buggy tires id be willing to get rid of them for $55 shipped , selling my car soon and dont need them , email me at wurydaz@aol.com
jhautz
jhautz's Avatar
10.26.2009, 02:48 PM
Mike had CRT.5 17mm adapters on display in the FLM/RCM booth this weekend at iHobby. They said they should be available in a couple weeks from what I remember. They looked sweet. Much better than shimming up the slash adapters. Return the ones from amain and hold out for the ones intended for CRT.5 is my opinion.
to make it...
or break it...
Silent...But Deadly
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.14.2009, 01:01 PM
http://rc-monster.com/proddetail.php?prod=crt.517mm
Design works equally well with the crt.5 or mini hyper - the adapter fits over any 12mm wheel hex. The 17mm nut includes a locking set screw to prevent loosening, and is threaded to the stock axle(m4 threads). We may offer different offsets and perhaps different nuts(for 5mm axle, for example) in the future, depending on demand.
