AKA vs Proline
Shark413
Shark413's Avatar
AKA vs Proline - 09.26.2009, 02:11 PM
Anybody have any extended run time on the Proline Revolvers or Cailbers? I have been running AKA's since they came out but the new Proline Calibers look promising so I bought a set, but have not tried them yet. One thing I like about the AKA's are the foams last a long time, so you can buy just the tires and reuse the foams which saves you a few bucks.
I found that the AKA tires are wider and taller than the Prolines. Calibers shown are mounted on V2 rims which are supposed to be wider than the regular Velocity rims.
AKA on left Proline on right
AKA truggy foams (on the right) after a month of racing, Losi foams on the left show some wear and are much softer than the AKA's.
Big pile of tires, mostly AKA but there are Proline Revolvers, Calibers and SC Bow Ties as well.
The reason for all the tires, two brushless truggies, one buggy, one CRT.5, a Crawler and a SC10.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
09.26.2009, 03:07 PM
I made a mistake in buying the M2 compound for my Revolvers. M3 is the way to go, but i've pretty much stuck to AKA's ever since. They last a long time and they wear very evenly. Also, the tire is mostly supported by the foam instead of the sidewalls, which in my opinion makes the tires more forgiving.
Area 52 Ranch Raceway
T.R.C.R.
bdebde
That's All Folks!
bdebde's Avatar
09.26.2009, 04:04 PM
Proline V2 rims are only taller, V3 rims (and tires) are wider.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
09.26.2009, 05:37 PM
I ran my buggy today with V3 revolvers in M3. I really liked them a lot. I did loose a tick of steering in the corner due to the width so I'm gonna get a set of revolvers in V2 for the fronts. The track was unprepped, dry and dusty and traction was actually pretty decent.
leeboy
09.26.2009, 10:23 PM
aka foams are the best!! when tires are done, we cut it open and keep the foams.
