Help Slash 32P Gearing
mambarustler
Kiss My Ass NITRO!
mambarustler's Avatar
Help Slash 32P Gearing - 10.11.2009, 10:12 AM
Hi,
I have quite a long time I havent used my rc's. Well I decided that since I don't have the money right now to finish my crt.5 conversion I might aswell find a use for the medusa 36-50-3300KV 5mm shaft I picked for $50. So I figured the cheapest and a safe way would be to go 32P, I am using a mamba max, the medusa, 3s lipo, and stock tires. Now what would you guys reccomend? Am looking to be running in the 40-50MPH range without having heating issues and such. Any help would be much appreciated.
Thanks
E-REVO
Slash 4X4 PE MM/Medusa 3300KV
3PM 2.4Ghz
WANTED: MMM/2200KV COMBO
  Send a message via AIM to mambarustler
10.11.2009, 10:55 AM
Differential Ratio: 1
Transmission Ratio: 2.727272727272727
Other Ratio: 1
Spur Tooth Count: 58
Pinion Tooth Count: 16
Total Voltage: 11.1
Motor KV: 3300
Tire Diameter (inches): 4.3
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0.007
Spur/Pinion Ratio: 3.63 : 1
Total Ratio: 9.88636 : 1
Tire Circumference (inches): 13.51 inches (343.12 mm)
Rollout: 1.37:1
Total Motor Speed: 36630 RPM
Vehicle Speed: 47.4 mph (76.14 km/h)
Effective KV Value: 3300
KT constant: 0.41 oz-in/A
I would work around that kind of setup- maybe a smaller pinion or larger spur- all the emaxx 3905 ones will work + the jato3.3 ones (54t upto 68t).
http://www.scriptasylum.com/rc_speed/_top_speed.html
