_dV
12.18.2009, 02:08 AM
Freezebyte: Your pics and procedure are virtually identical to how i did my badlands except of course i used beadlocks.
Did you use air holes in the wheels or tires?
Whats the longest you have had your strapping work for?
Freezebyte
12.18.2009, 02:17 AM
No, I did not punch any holes in the tires, the rims where already holed out for me and that allows plenty of air movement for my needs. I've yet to have a strapping job go bad, but I haven't run these tires for very long either...
Desert Rc
12.18.2009, 02:47 AM
I am digging the hpi gt-s tires!! I have to say the rob really relies prob with the wider tape. Plus only one solid pass and only overlap what is needed to make a good hold. The thin strap is prone to pulling easier.
Ascender
Ascender's Avatar
01.01.2010, 10:37 PM
IUse the same technique except for one thing: using hardcore duct tape eliminates the need to wash the tires. The adhesive on good 3M heavy duty duct tape has no problem at all sticking to tire rubber even with the anti-aging crap still on them.
Freezebyte
01.01.2010, 10:56 PM
I have a hard time believing that, but whatever works for you.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
01.01.2010, 11:44 PM
It's Mold Release , should still clean tire prior to glueing for the best job possible and better adhesion.
sharkattack99
01.07.2010, 01:22 AM
im currently using HPI's Supper Mudder tires on maximizer beadlock wheels. i love them work excellent on pavement or grass dirt seems to be a pretty versitle tire.
ID:	8285   Click image for larger version
ID:	8286   Click image for larger version
Nard Cox
n00b
01.07.2010, 08:17 AM
Kinda looks like Proline Mashers ... only different
_dV
01.07.2010, 10:10 AM
did you happen to weigh them before you mounted them?
lot larger diameter\profile then the mashers. 165mm diameter vs ~147mm
sharkattack99
01.07.2010, 05:13 PM
no i didn't i don't have that kind of scale.
_dV
01.08.2010, 01:04 AM
Couple of quick pics. Just finished putting this combo together. HPI GT S tires, HPI firm foam, JConcepts Rulux 1/2 offset half ups (3.7 inch diameter) dyed black. Tires are mounted on the inner bead of the wheel and strapped with tape. I glued both on the inner bead and the outside edge of the wheel. This gives the GT S tyre roughly the same profile as an MT sized Badlands.
Combo weight is ~360gm (wheels are 60gm). Also, i'm not sure how i got the GT S\Maximizer 386gm weight in prev post. When i reweighed it was ~400gm which seems right as the maximizer wheel weighs in ~100gm.
Few more pics here
Nard Cox
n00b
01.08.2010, 04:49 AM
Looks good! Are those LST shocks you have on there? How are they holding up with bashing?
_dV
01.08.2010, 09:46 AM
They are the all plastic Aftershock LST type shock with Hot Racing shock cartridges\boots and Raven dual rate springs. Haven't had them for long but they are standing up ok so far. I popped a cap and bent a shaft on one after a rather high nose dive off a bmx jump with 40 centistoke oil but apart from that all good.
V0RT3X
Muggy love
V0RT3X's Avatar
01.08.2010, 05:01 PM
How's the air control with that taped GT S'? I taped my 3.7 road rages and air control was terrible so I sold them. (on the erevo) Don't want to screw up again, but I don't think there would be so much ballooning on 4S.
_dV
01.08.2010, 05:51 PM
V0RT3X: Took the new wheel\tyre out for the first time yesterday for a short run. It was only on flat ground though, no jumps.
I have run with these tires taped briefly on smaller diameter wheels and air control was fine. A little more sensitive than other wheels i have run which was probably due to the higher relative mass of the tires to the truck. I've also run taped badlands and air control was great.
What happened when you taped your road rages that made air control terrible?
There is a lot of ballooning on 4S with the Flux.
