revo not running right
Trick440
revo not running right - 01.30.2006, 11:12 AM
I just have a stock revo. The motor won't turn over. Any clues on what I should check? When I use the EZ starter I push the button both light light up but nuttin happens.
This happened I think because i rinsed the revo off in the sink.
Sylvester
Sylvester's Avatar
01.30.2006, 05:17 PM
Check if all the ez-start wires are intect, as well as every other wire in the truck.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
01.30.2006, 05:19 PM
Could be a vapor lock. Take out the glow plug, turn the truck upside down and hit the EZ start. If it is a vapor lock, with the glow plug removed the motor will spin(and dump the excess fuel onto the ground). Re-install the glow plug(test it to make sure it is good) and start it up. If the glow plug is bad and you tried to start it for a bit(turning it over), then it most certainly is a vapor lock.
Trick440
02.04.2006, 11:28 PM
The problem was intermittent at the starter. I checked every wire and did alot of wiggling, couldn't get to work.
So I replaced it with a new one.... And of course the one I took off now works. But that was the problem bad starter.
I'm learning water is real bad for these things. I fried the opti drive electronics also. Atleast I'm getting to know the local hobby shop guy real well...
Sylvester
Sylvester's Avatar
02.04.2006, 11:58 PM
Glad to hear you got everey thing fixed, yes electonics are bad when they mix with water, thats good to know that you are learining, also, your LHS guy should be real happy after mud bogging:D
Losi 8ight e
