kalbien
01.14.2010, 05:17 AM
its the proline body for the rc8t. doesnt fit perfect but im gonna use it.
tell us how that went. It's not looking bad actually. If it fits, I think my new one is going to be this...
and of course, that conversion is nice as well, but that body.. hmmmmmm
moogenite
Let non survive!
moogenite's Avatar
01.14.2010, 12:58 PM
Does the motor mount split? looks like the front mount is 2 piece?
rootar
rootar's Avatar
01.14.2010, 01:15 PM
yep, easy access to the centerdiff!
rootar
rootar's Avatar
01.14.2010, 01:40 PM
more pics.
ID:	8354   Click image for larger version
jhautz
jhautz's Avatar
01.14.2010, 02:35 PM
Where is the servo mount plate/rx tray/transponder mount? Should have one I thought.
Why did you flip the arm on the servo saver to run the inboard steering linkage?
to make it...
or break it...
Silent...But Deadly
rootar
rootar's Avatar
01.14.2010, 02:50 PM
Mike forgot to send my servo tray piece but then he had the idea to see if flipping the servo arm around to so if it would work and it does. so i think he is gonna work on a Rx box to go in the new found space....
jhautz
jhautz's Avatar
01.14.2010, 03:18 PM
Hmm... I looked at the flipped servo saver arm when I originally built mine and it either contacted the steering link plate or was really, really close. Its been a while now though. Gonna have to look at that again.
to make it...
or break it...
Silent...But Deadly
rootar
rootar's Avatar
01.14.2010, 03:19 PM
it is very close to the steering link but it goes lock to lock without actually contacting the steering link.
moogenite
Let non survive!
moogenite's Avatar
01.15.2010, 12:48 PM
Reversed steering doesn't work on my XT8'09, it hits and left trow is reduced 25%.
can one use the 52 mod1 spur?
rootar
rootar's Avatar
01.15.2010, 07:41 PM
im getting 100% throw both ways and ive got 2mm of clearance at full left.
jhautz
jhautz's Avatar
01.15.2010, 09:18 PM
I double checked on mine and it won't work either. The 09 has the CF ackerman plate and it's wider than the aluminum one on the older XT8 so it would hit sooner. Also I have the aluminum hubs that I dremeled a little to get more steering throw so that's not helping.
to make it...
or break it...
Silent...But Deadly
moogenite
Let non survive!
moogenite's Avatar
01.16.2010, 04:43 AM
me too have alu hubs and dremeled them for more trow.
Rootar has the carbon ackerman too, where is the difference then?
jhautz
jhautz's Avatar
01.16.2010, 09:19 AM
Maybe the difference is just the hubs then? Not sure.
to make it...
or break it...
Silent...But Deadly
rootar
rootar's Avatar
01.16.2010, 12:44 PM
i havent dremeled these hubs for more throw yet.... they are off an xb8 buggy i have. but if i did dremel them for more toe i could swap back to the older aluminum steering link and gain another 3-4mm of clearance for more throw.....
im not sure what exactly is hitting the steering link on yalls trucks either the plastic ball cups or the servo saver but i put i just put a shim under the servo saver to just barely lower the ball link and now when it goes full lock if it kept going the steering lnk would go inbetween the ball cup and the servo saver all the way to the ball studs post... so thats another 4mm of clearance
moogenite
Let non survive!
moogenite's Avatar
01.16.2010, 02:35 PM
with a 2mm shim mine hits with the flange on the ballstudd and i need maybe 2mm more trow to left to get full travel.
i could shave the flange...
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
