Go Back   RC-Monster Forums > RC-Monster Area > Product Reviews
03.04.2010, 11:12 PM
Hmm, maybe there is an issue with radio calibration or something in georgec's setup. I didn't doubt his findings based on my experience with the older EZRun 80.
asheck
03.04.2010, 11:35 PM
I'm running mine sensored and it's smooth as can be . I got the programming card, and had to turn my brakes up to 75% , but they seem to have good modulation before locking up with a 2wd.
georgec
georgec's Avatar
03.04.2010, 11:36 PM
I didn't test it on carpet either! whether or not that would make any difference I'm not sure. Most of the tracks I run at are brick hard with marbles on top. As for the "lurch" it wasn't huge just irritating. I'm sure my old trigger finger isn't as nimble as it once was and that is where I found the MMM breaking to be more forgiving.
03.04.2010, 11:43 PM
Maybe your neutral range is too wide, so it starts off with higher power giving you the lurching you speak of? As far as the brake goes, I have no idea. Maybe make sure your reverse EPA is set right (100%) and recalibrate?
burnineyes
03.05.2010, 12:20 AM
I do not own any of the larger 8th scale systems right now, but I do own several 10th and 18th scale systems from Castle and EZrun. I prefer EZRun in almost every car I own for its smoothness and driveability. Its too bad to hear that this one did not perform as well as expected. I hope this is just a bad case and not the norm.
reno911
Smelly Nitro meet your maker!
reno911's Avatar
03.05.2010, 01:24 AM
I'll agree those EZrun 60 amps have replaced almost all of the 1/10 scale short coarse truck systems at my local tracks.
I run 75% brake on my XERuns. I believe i have a higher setting on the punch too, I'll have to check. Ultimately I would say I am satisfied with the system. If there are some faults to it I would say that I probably don't notice them that greatly since I have learned it's characteristics and just adjusted myself to it, rather than the other way around.
Like Brian said calibration of your radio to the ESC could play some factor there as well.
adrictan
03.05.2010, 12:18 PM
I'm on the 150a with my RX8 motor on my truggy. I did not see any cogging nor did the braking effect affect me.
georgec
georgec's Avatar
03.05.2010, 05:37 PM
I would imagine the Xerun coupled with one of the Tekin sensored motor would work quite well.
georgec
georgec's Avatar
03.15.2010, 09:57 PM
I hope to outrun him this Sat. For the first time in over a year or I'll be buying the brews afterwards....again
notatoy
notatoy's Avatar
04.14.2010, 06:31 PM
any updates george ???? i here the mmm is getting a wright roasting on traxxas forum http://monster.traxxas.com/showthread.php?t=516908 but of course it is user erorr . a not castles fault , .lol..
georgec
georgec's Avatar
04.14.2010, 09:13 PM
Well hello notatoy. For just a season opener it turned out to be quite a race! There were almost 100 entries in all classes combined, 3 heats sct, 3 heats nitro truggy, 2 heats nitro buggy, 1 heat 1/8 E buggy, 1 heat 1/8 E truggy. It was the first time there were enough E truggys to have a separate class and since my bud Mike runs a truggy I didn't get to race against his sorry a$$ LOL !!! But I did manage to turn better over all lap times...so he bought the brews that was nice for a change! As for the opinions of those on the Traxxass thread....not so much I don't place much value on the opinions of those that don't race, there experiences bashing have nothing to do with racing, therefore irrelevant...to me
fastbaja5b
fastbaja5b's Avatar
04.14.2010, 09:57 PM
I dunno about "user error" I had a MMM let go a month ago on a 2s Lipo set up with a Medusa 3000kv motor, max amp draw by a Wattsmeter was 72 Amps
Now have an el cheapo Venom 120 Amp (Speed Passion) in there and it's good as gold.
1 MMM, I could tolerate, 2, maybe. I went through 6 of them before I chucked it in.
MM and MM Pro are fine though :)
The MMM and I will soon have to have a restraining order against each other I think.
Say Less, Do More.
notatoy
notatoy's Avatar
04.15.2010, 04:13 AM
i understand george sounds great , and ohh i agree 100% that traxxas forum pretty much full of idiots to be honest this is the only forum i know of that does talk sense for sure
bumsnogger
04.21.2010, 11:25 AM
Hi guys,I've been looking for a brushless combo for my summit,I don't race it,I'm a Brit ,so theres no pne to race,lol.The EZRUN 5200kv works well in my ml$t2,keeps wrecking diffs.Do you guys think it'll work in the summit,its heavy?
notatoy
notatoy's Avatar
04.21.2010, 11:41 AM
i think they will work in your summit however i would use a lower k,v motor than then one your using now around the 2000k,v should do it .. ohh iam a brit also .lol.. and i know what you mean ..
