MMP on 6s do I need to change wires?
FastXR
MMP on 6s do I need to change wires? - 03.15.2010, 03:14 PM
As the title states im wondering what the min. wire gage I need to run my MMP on 6s with Tekin T8 1400Kv motor in HB Ve8 on 6s 2650 40c lipo. Will I be OK with all the original wiring on the MMP or do I need to go up to a larger gage? I know the MMM uses a much larger gage wire. What do you think?
snellemin
2 KiloWatt RACER
snellemin's Avatar
03.15.2010, 03:47 PM
I don't think you have too. You won't be pulling that many amps on 6s with the 1400kv motor.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
03.15.2010, 04:52 PM
Wire gauge/diameter is a function of current, not voltage: higher current require larger wire. Like snellemin said, if you're running 6s on a low current setup, the existing wires will be fine.
FastXR
03.15.2010, 06:25 PM
Ok thats what I thought I just wanted to confirm before I went ahead and ran it. Thanks guys! I'll let you know how it works out.
